07-13-2006, 09:26 AM
Putnam
, Connecticut
495 North of Boston
The last trip around Boston on 495 was really rough. There is a section where the bumps at the bridges try to tear your trailer apart. I should have marked this on my map but was to busy making up new funny words. Any of you Boston Urbanites know what sections this is so I can avoid it on my way to Maine?
07-13-2006, 12:11 PM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
it was pretty much the whole northern half, as far as I could tell...
last trip on it was for the Monadnock rally, where travelled from Lawrence to Littleton...it was just as bad as ever. No reason to believe its any better between Littleton and Worcester, but I haven't been that far in quite a while.
Last time I had to head in your direction, I did some measuring on the map. I found that taking 128 was only a few miles longer. I can't remember exactly...maybe even less than 5 miles. Whatever it was, it was a no-brainer...WAY worth the much smoother ride. I would stay on the pike to 128, take that to where 95 splits off and heads north. (Peabody). Stop at my house for coffee. (1 mile off 95).
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
07-13-2006, 01:58 PM
Putnam
, Connecticut
Thanks Chuck..
07-13-2006, 01:59 PM
1 Rivet Short
1989 25' Excella
By The Bay
, Rhode Island
I travelled 495 this weekend, didn't think it was bad. I use 495, rather than 128, as it provides a shoulder to pull off on if needed. If you get in trouble on 128-good luck!
Maybe I am missing something.
495 is LONGER than 128 but to us, provides a certain margin of comfort/safety.
I guess if you are not going durring rush hour (when is it NOT rush hour?) then 128 might be ok.
Just my experience...
07-13-2006, 02:23 PM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
well..."it depends".
if you're going from RI to ME...you're going much farther out of your way to take 495. You'd only save time vs. 128 under the absolute worst of traffic conditions...and if they're that bad on 128, they'll be bad on parts of 495, as well. I've seen backups on the northern half that stretch for 15 to 20 miles.
over59 would be coming from much further west...it would be a shorter trip mile-wise to take 495. but only slightly longer to take 128.
I can't speak to the southern half of the road, but from Worcester to Salisbury, the overpasses are in absolutely terrible condition. I had cabinets knocked off the walls of my trailer the last time I took that road. And I wasn't driving at high speed. (~60). The thing is, the rest of the road is fine, so everyone is moving right along...then you hit an expansion joint "all of a sudden"..and B-BANG!!!
I can't think of a location on 128 where there is no breakdown lane.
rush hour is anywhere from 6-9am and 4-7 pm. the rest of the time, its fine...unless there's some kind of unusual catastrophe.
Air:291
Wbcci: 3752
'73 Safari 23'
07-13-2006, 02:34 PM
Massachusetts
Originally Posted by chuck
...I had cabinets knocked off the walls of my trailer the last time I took that road...
Did you forget to screw the cabinets to the wall?
It's not THAT bad if you travel at 60 mph, leave a few car lengths in front of you so you can see the "bumps" and "holes" and then you will have time to maneuver around them. If you travel at 60 mph in the low speed lane, then everyone will be well out of your way by the time they pass you (traffic typically averages 75mph) which will give you plenty of room to maneuver. If you happen to get caught in rush hour traffic, that is not a problem either because traffic is crawling at less than 5 mph. You should have no "cabinet failures" at that speed but then again, I think Over59 is using screws to attach his cabinets to the wall.
WBCCI Region One
Attitude is the only difference between ordeal and adventure
07-13-2006, 03:50 PM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
well...lets see....you showed up at the same destination, having taken the same route, -1 in the tire column. do you think that was a coincidence?
the airstream factory did use screws to attach this particular cabinet...they don't hold in fiberglass that well. (rear endcap).
you can't go slow enough on that highway to see and avoid these joints. On the odd chance that you do see one in time to do something about it, you'd have to slow so much that you'd risk getting rear-ended by someone. going "slow" doesn't have much affect on the other vehicles on the highway; if people are passing or in the process of passing. you just can't move around them.
I remember in truck-driver school, they had some real numbers that escape me at the moment...but the point of the explanation inolved a similar scenario, only at night. headlights are focused at "x" distance; Shortest possible stopping distance with "y" load and perfect reflexes (which we don't have) is <x. If you see it, you're going to hit it. Swerving will get you AND "Bambi" killed.
I know, we're talking day-time, but the same principle applies, because these are smaller targets. Believe me, I tried doing just that, because I knew they were "out there"...didn't work.
one possible explanation for this differing opinion of the road conditions is that you have a shiny new trailer, (and so does BillTex) with a presumably bouncy axle, and I do not. we're going over the same bumps, and you don't feel them, because you've got a heavier truck, a lighter trailer, and way better insulation in between.
Air:291
Wbcci: 3752
'73 Safari 23'
07-13-2006, 04:03 PM
2006 19' Safari SE
NW of Boston
, Massachusetts
I live between 495 and 128 and I agree with you completely, BillTex. In general, the traffic is much lighter on 495 than 128, even during rush hour, and you're much less likely to run into a jam. The only place I can think of where the roads get a little bumpy is around the construction area in the Lowell area. Haven't been through there in a while though. I spend more time on 495 South of around Rte.2.
Doug & Jamie, AIR #650
07-13-2006, 05:30 PM
Putnam
, Connecticut
Last time you there was going to Salisbury Beach Rally. The road was really good, except at the bridge joints for one area. In a car they were nothing. With the trailer they hit hard. Looked like they dug out the pavement , scored the bridge, and never came back to pave. Problem is you have to slow down to 40 and that's not good. I'll go 128 until Mass fixes the road. The southern end toward the Cape is no joy either. Not doin no tunnels up there either. Changed all our flight plans from Logan to Bradley in Hartford/Springfield.
07-13-2006, 08:06 PM
1 Rivet Short
1989 25' Excella
By The Bay
, Rhode Island
Chuck-you raise an interesting perspective. I have mapquested the route and also hand calculated, not sure either one is correct, but I get a difference of 8-13 miles RT 495 VS RT 128.
(Someday I will actually clock and know for sure)
I have always had the mind set that when towing, 495 is better. When nt towing I drive 128 or right through the city-SE XPWAY to 95.
We do head up north quite often from RI so we get to experience pretty much the entire length of those roads.
We will be heading up that way again next week-maybe I will try 128, we'll see what time of day I get there.
Is a 1989 Excella really "shiny and new"?
It does tow nice, and I did not have any "big bangs" or other scary instances on 495. Never did while towing SOB's either. But then again, I have never taken 128 while towing. Maybe I am missing something.
It sure is nice to hear from others who travel these roads. Especially those who are even closer than I.
Good post-and timely too-we are going up that way many times this season!
More input appreciated!
Thanx, Bill
07-13-2006, 08:48 PM
1993 25' Excella
Full Time
, Anywhere USA
Thanx, Bill
Hi BillTex,
We found some bumps and potholes when we headed "down south" on Route 495 for the Scusset Beach Rally which was held in mid June this year. But, for the most part this is our (well, my) preferred route because there are less commuters on this highway. On Route 128 we find folks don't seem to understand that we are pulling a 7500 lbs+ (fully loaded) trailer behind us and that we need more space between us and the guy in front of us to be able to stop safely. On Route 128 we've had folks cut in front of us with 2 feet to spare with the traffic ahead breaking hard - YIKES, what are these folks thinking! We cannot stop on a dime! Not that non trailer folks on Route 495 know to give us the space we need to operate safely, but there are alot less of them.
Michelle & Leon
New England Unit
07-14-2006, 05:13 AM
Massachusetts
...We do head up north quite often from RI so we get to experience pretty much the entire length of those roads.
We will be heading up that way again next week-maybe I will try 128, we'll see what time of day I get there...
If traveling to Maine from RI, the shortest route from RI, when not towing is:
1) 95N to 128S (go right at the 128 split to go thru Boston)
2) Go over Tobin Bridge (I think it becomes Rte 1 at some point)
3) Rte 1 to pickup 95N again in Peabody area
If towing, note propane tanks aren't allowed in the tunnels, so I found the shortest route from RI is:
1) 95N to 128N (go left at the 128 split)
2) 128N to 93N to 495N to 95N OR 128N to 95N
Note, taking 495 all the way from RI is longer because 495 swoops out to the northwest before it heads back northeast again.
I have never recorded the mileage both ways but have noted the time and it is usually 1/2 hour shorter if you avoid 495.
WBCCI Region One
07-14-2006, 06:18 AM
1 Rivet Short
1989 25' Excella
By The Bay
, Rhode Island
I agree, 95-RT1 is the shortest when not towing.
I still believe that 495 is a little more comfortable than 128 when towing though. The extra 1/2 hr is worth it to me, I just find driving 128 much more stressfull. I try not to worry much about time when towing. As noted previously, Mapquest indicates somewhere between 8 to 13 miles difference between the 2 routes, and I feel more comfortable on 495. I can't say I noticed any particularly bad stretches either as commented above? Cetainly no worse than other roads (128).
Has anyone ever actually checked the odometer driving both of those stretches? That would be interesting...(not sure I believe the Mapquest figures, they can be WAY off sometimes!)
07-14-2006, 06:35 AM
2006 19' Safari SE
NW of Boston
, Massachusetts
Yuki, won't 95N to 128S take you west around Boston through the suburbs? I think 95N to 93N takes you through Boston and the Tobin Bridge/Rt. 1
I still prefer 495 over any of this though. In the summer you're not only going to get rush hour traffic (including travel in the breakdown lanes), you're also going to see a ton of traffic from Boston suburbanites going to the Cape, Thursday to Tuesday. Add rain and you're going to have accidents and backups every mile. A few weekends ago it took me about an hour and a half to get from 95N to Rte 225 exit using 128, about 17-18 miles, because of rain (no accidents). This was on a Saturday.
07-14-2006, 08:55 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
nope. not from RI. well..."kinda". This is the inherant confusion caused by overlaying route numbers...and probably why no one from "around hee-yuh" ever refers to any part of 128 as "95", or "93", even though technically, they are the same in some spots.
So...from RI, 95N to 128S goes toward Boston. 128S in this area is actually heading east. But its also 93N. and will take you through Boston...But 95N to 128S will loop around Boston through the western suburbs.
There. is everyone from outta-town thoroughly confused, now?
yeah, that can happen any time...particularly on the southern tier. Rain=bad on that road...I think because it has a "feel" of having less room, because the road is lined with businesses, and it curves and pitches more than most limited access highways...the sight lines are short. There's as much asphalt there as anywhere...but it doesn't "feel" that way. So at the slightest disruption, everyone slows down too much, and gridlock prevails.
Its always a good idea to keep an eye (or ear) on the traffic reports, if 128 is in the cards for you. But typically, on the weekend or non-rush hour, I'm as comfortable on that road as any other.
Now...the SE expressway...yikes. That really IS congested. the lanes are narrow, there's no median...jersey barriers just inches from the left lane, AND no break down lanes. Even though its mostly flat and straight, I find it to be extremely "white-knuckle-y". I'm sure a big part of that is that I'm not used to it...don't go there, much. But whenever I do, I always have this great feeling of relief when I exit.
Air:291
Wbcci: 3752
'73 Safari 23'
07-14-2006, 09:28 AM
2006 19' Safari SE
NW of Boston
, Massachusetts
Isn't that what I just said? Ohhhhhh, noooooooo, I'm so confused!
-J
07-14-2006, 09:50 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
yeah, I just measured...got 12 miles difference. not that much, in the big scheme of things, and not as much as I thought.
the difference for Over59 is only 6 miles. (from where 190 intersects the pike, to 128 via 90, then N to 95, to the intersection of 495, vs. 190>290>495 to the same spot).
If you feel that way...then it is. for you.
way more so than a 73 with shot axles.
I probably need new axles. But I had the same experience as '59...the road itself is fine; its just that they never fixed the overpasses. and the shocks were enough to dislodge "everything" inside the trailer.
Air:291
Wbcci: 3752
'73 Safari 23'
07-18-2006, 10:04 AM
1 Rivet Short
1989 25' Excella
By The Bay
, Rhode Island
Need advice going to Maine
Heading up to Waterford ME this Friday (yeah-I know, traffic city!) Waterford is north of Fryeburg, south of Bethel.
Unfortunately, due to my departure time, I will hit the Portsmouth/Portland area right around 5:00 if I go 495-95 N.
I am considering taking RT 16 heading toward North Conway and then 302 over towards Waterford. A llitle more scenic than 95 N all the way, especially with the anticipated traffic around Portsmouth.
Any advice opinions? (Not on the 495 versus 128 section-I am going 495. Just interested in the stretch north of Boston)
Thanx, Bill
07-18-2006, 10:19 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
I haven't been through Portland during rush hour lately, but I have been up 16 through Portsmouth toward the White mountains quite a few times recently, and it is nasty. Long backups for many miles getting out of portsmouth on 16.
Portland is an hour past Portsmouth, without traffic.
If 6 pm traffic in Portland is likely to be that bad, what I would do is get off 495 in Haverhill, and take 125 up to 16, and continue from there. That'll also save you quite a few bucks in tolls.
Air:291
Wbcci: 3752
'73 Safari 23'
07-18-2006, 10:23 AM
1993 25' Excella
Full Time
, Anywhere USA
Thanx, Bill
When you first exit route 95 and enter route 16 the traffic can be pretty backed up as route 16 is an undivided, two lane highway. After that it's pretty good, there are a few steep hills but they have slow lanes for those of us who are towing to use. As you go through Center Ossipee wave to our vacation home, we never use it now that we have our Airstream...
Michelle & Leon
New England Unit
