Old 08-14-2021, 04:16 PM   #1
brea , California
What is this for? Help
Hi! We acquired a 1972 overlander back in may and have been slowly making her our own and loving (maybe hating) every moment!
Anyways she’s got this extra long back platform that I have searched forever to try to find out what it’s for. I purchased it from the original owner and so I think it’s original but who knows I could be wrong.
Can anyone help tell me what it’s for?
ID:	401872   Click image for larger version
jillianbug22 is offline   Reply With Quote
Old 08-14-2021, 04:37 PM   #2
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
That rear bumper looks like it was extended by a (po) previous owner. Look underneath and you may see that the frame rails either side have an extended piece of metal welded. The smaller section that opens up would be storage compartment where you would put your sewer hose ( stinky slinky). Depending on the construction of that extension you don't want to put to much weight there. You don't want it to pull down and away from the trailer. When you look inside is that whole section hollow for storage?
Hoses, Lego stacking blocks, a rolled up rug on top maybe.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 08-14-2021, 05:14 PM   #3
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
Looks like a holding tank was /is in there. Or did they just extend the pipe out for convenience?
Brian
ITSNO60 is online now   Reply With Quote
Old 08-14-2021, 05:22 PM   #4
brea , California
Here is a look underneath. Anyway to know for sure if it was added by a previous owner or if it is original? The lights are functioning as well and are the same as the other brake lights on the trailer.
ID:	401878   Click image for larger version
ID:	401880   Click image for larger version
Old 08-14-2021, 05:33 PM   #5
"Cloudsplitter"
An add-on to store the 'poop' stuff, not an AS option.
Old 08-14-2021, 05:37 PM   #6
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
Some of the older models came without gray tanks didn't they? At any rate if there is a holding tank in there whatever you do don't ever tow with it full, it could really cause problems with sway.
Brian
Old 08-14-2021, 05:40 PM   #7
brea , California
No tank inside that part. Just storage. There is only one tank under the bathroom as far as I know.
Old 08-14-2021, 05:41 PM   #8
brea , California
Haha good to know. Where on earth would people store the nasty stuff with the originals??
Old 08-15-2021, 09:21 AM   #9
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
The narrow part that opens is for your electrical cord. Most often people carry their slinky in a pvc tube mounted under the trailer. Does the large part open up and separated from the original? If so that is where he stored slinky. Can you ask original owner?
Streamracer is offline   Reply With Quote
Old 08-15-2021, 12:19 PM   #10
Cedar Hill , Texas
Two things:
1 - Here is a time consuming way to confirm if the add-on is for wastewater. [BTW, I've done this, but for other reasons.] Check your manual (or google) to determine how much wastewater storage you should have, i.e. 30 gallons, 40 gallons. Then you can get a water meter (https://www.amazon.com/gp/product/B0...8D2FH3WRX&th=1) OR you can do it the painful way like I did. Pour one gallon at a time into the toilet until the you reach the printed amount. If you have more room in the tank you know the PO increased the size of the wastewater storage tank. Now that you have gotten this for, may as well go head and fill the tank until it will hold no more. Then you'll know the total amount of wastewater (in gallons) that you have available.
2 - From looking at the pictures you provided it appears that the PO has make you a easy access way to flush out the wastewater tank. Hence the copper pipe that is just to the left of the drain pipe.
I "assume" there is some reason you can not contact the PO to inquire as to what or why he/she made this add on.
fthopkins is offline   Reply With Quote
Old 08-15-2021, 06:51 PM   #11
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by fthopkins View Post
T
That's the area the stock city water connection was in that era AS.
help, help, help. new to it all. ohwally Member Introductions 5 08-24-2008 04:18 PM
HELP HELP HELP!! Lug nuts & Stems Chitown AirStreamers Wheels, Hubs & Bearings 4 08-18-2008 04:41 PM
Hot Water Heater HELP HELP HELP!!! Igor68 Water Heaters, Filters & Pumps 2 06-22-2006 08:07 PM
Help Help Help!!! rebel beck 1974 - 1979 Sovereign 9 01-07-2006 03:00 PM
