RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-21-2021, 05:38 PM   #1
Ridgecrest , California
silver streak
just bought a 31 ft silver streak and i have no running lights fuses are good? also looking for a fridge for it 1978 they pulled the old one out and put in a 120V I would like to put it back to the pro pain one
Hotrod68 is offline   Reply With Quote
Old 02-22-2021, 11:18 PM   #2
1960 22' Safari
in the wilderness , The great Mojave Desert
You got a very nice and well built trailer. Congrats!
Have you gone over everything with a continuity tester? Also check the bulbs for corrosion.
Best to you.
P.S. Post some pics.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 02-24-2021, 08:36 AM   #3
drmox's Avatar
Villa Park , Alabama
My '76 Sovereign has had intermittent problems with the running lights. My trailer is very updated, but has never experienced a complete frame off rebuild. Therefore, the wiring in the walls has become a somewhat confusing mixture of old and new.
After checking the usual suspects: umbilical cord and connections, fuses, breakers, bulbs, etc., your problem is pretty much narrowed down to a short somewhere. It's like a string of Christmas lights; they still work if one bulb goes bad, but a short along the loop of lights shuts them all down.
To narrow down the location of the short, you can take the covers off the lights, and use a long piece of wire to "jump" the circuit from one light to the next. When they light up, you'll will know the short is somewhere between those two lights. If you possess a wiring diagram for your model, you can make an educated guess where your short may be. Or if you remember doing work or driving a screw into the wall in a certain spot...
Good luck.
drmox is offline   Reply With Quote
Old 02-25-2021, 08:51 PM   #4
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
A bad ground might be the culprit. With the tow vehicle connected, lights on, take a simple 12 v test light, and see if it lights up dimly with one end clamped to bare metal on the trailer, and the other end, a probe, jammed into the metal of the tow. If it glows, even dimly, your ground connection is faulty.
Tom
AIR 71620
WBCCI 5809 Reg 9 Unit 155
2008 Classic 30'
2019 F250 4x4
tvketchum is offline   Reply With Quote
Rare Silver Streak Motorhome, Like Airstream All Silver eBay Watch Airstreams on eBay 0 07-29-2011 07:04 PM
Silver Streak Pic's or sites? pdxor97225 Off Topic Forum 5 02-01-2004 08:23 AM
