I have a 72 Avion and need to replace my original antenna. Looking at replacements, some require power for the amp. Do the original antennas have power wired to them or is it just a coax? If there is no power, I would have to rethink about placement in order to run power , may just have to go with a non-amp.
I think the only thing going to the antenna itself is the coax or flat wire. The amp wold be mounted inside somewhere, and that is where the power is needed.
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
1966 28' Ambassador
Mobile
, Alabama
Typically the amp is located at the tv antenna location near the beds and is identifiable via a small button you push to turn on and off. Some have a small light that comes on when turned on. You might consider going with a modern omni directional antenna that does not have to be raised or lowered. I have done that on both my Avions have had good reception with no hassle.
Thanks, I yanked it out last weekend and just cut the coax at the base, then sealed it up. I will try an indoor one and if that doesn't work perhaps an omni.
