Old 12-19-2010, 11:56 AM   #21
Knoxville , Tennessee
Dec 19, 2010 Update!
Well, it has been a while since I have updated this thread. i have done a lot of camping and totally enjoy the trailer. It is awesome!
The curtains were driving me nuts because they had deteriorated so much from the cleaning and with all the rubber backing peeling they looked splotchy when ever thay were closed.
So I set about makng new ones and learned to sew in the process.
The camper has the extruded aluminum track rods with the roller sliders and hooks in the curtains. That is a really nice system as the curtains slide effortlessly. I bought new rollers as their plastic wheels were brittle from the sun. I bought K-mart premade curtains that have the same rubber thermal backing. I had to buy the entire inventory of two stores just to get exactly enough. The 63" long panels would make two when cut to length and the 84" long panels would make three except for the Rt side picture window which is taller.
The very front curved windows and the flat front windows and the adjoining side windows all come together. The track rod is continueous for about 16 feet all around. My camper has the wide rear window which took 3 panels. All in all 18 panels to do the camper. A lot more than I would have thought.
I honestly have at least 60 - 80 hours in these things! But I am happy with the result and save a lot of money.
As far as the blue velvet valences shown in my pictures They are original and will be replaced with wood. I'm going to wait until spring to get to them.
Now I have started re-working the rear bedroom due to rotted subfloor. I hope to have a whole new layout installed by early Spring. Here are the curtains:
ETN550 is offline   Reply With Quote
Old 12-19-2010, 12:04 PM   #22
Some more interior pics. It is emptied out for the winter. These were taken after I bought it and cleaned it.
Old 03-06-2011, 08:51 PM   #23
Some Warmer Weather Time to Get Started.
Focusing on the rear now. The subfloor was rotted in places mostly along the outside. My plan is to cut out what is bad, replace and build a new interior. I'm going to be putting aluminum skin on the walls and possibly a bamboo floor although I'm not sure. Here are some pics!
Rotted wall panelling. All due to an awning bracket leaking! (Not me, former owner!) Fixed now.
Floor so rotted I could push through it with my hand!
Rear Queen pedestal layout. Those little nightstand cabinets were the only rear storage except for the overhead compartments. All the space under the bed and beside the hot water heater was not accessable. My layout will have a lot of storage.
Rear paneling, insulation and flooring mostly out. One more section remains to come out.
Hot water heater removed, temp patch on exterior, converter.
Next I am going to do some wiring rough in to locate new outlets, lights, and cable tv jacks. I will be using 0.040" aluminum sheet for the walls. It will have a shiny brushed mill finish. It comes in 4 x 10 sheets. I'm planning on covering the walls, riviting it in place then cutting the openings for the windows, switches, and outlets. any suggestions or procedures for that? I bought some electric nibblers to cut the sheet aluminum.
Old 03-08-2011, 07:00 PM   #24
Vintage Kin
Fort Worth , Texas
Good pics, and nice progress. What shape was the wall insulation in where the awning mount leaked? Separated and clumped? How do the frame and stringers appear after the damp?
Old 03-09-2011, 07:36 PM   #25
Hi Ross,
Insulation on the leaky sidewall was sagging a little and discolored. Not as bad as I would have expected. Cheap enough to replace though. The floor insulation was run over the steel and the subfloor screwed down on top of the insulation. Although highly compressed between the subfloor and steel I think this creates an area to wick water. I might use the same insulation or I might make styrofoam panels for the floor. I'm going to use the "Great Stuff" expanding foam liberally too!
The main frame rails are 2" x 5" x 1/4" wall box tube which is pretty hefty and they showed little signs of wear other than light surface rust. The cross members are c channel made from bending sheet stock and are pretty light to begin with. They had heavier rust scale but are totally servicable as is. Some of the cross memebers have additional c channel welded to them where the belly pan attaches. The belly pan is in great shape. There is little reinforcing where the stabilizers mount on the cross members. What they say about not using the stabilizing jacks to take weight or lift the trailer is good advice!
What was interesting in the disassembly is that all of the heavy wall dividers that appear to be 3/4 thick plywood with veneer are actually panneling with an air space in the middle. Silver Streak was very consciencous about weight.
Also, the subfloor does sit under the aluminum footers that run on the perimeter of the floor and provide the spacing for the inside and outside wall sheeting.
This is how the trailer was built:
Weld the steel frame and paint
Lay the subfloor side to side and end to end
Lay the aluminum c channel track edge up all around the perimeter running fastners through it and the floor and, where over the stringers through them too.
Fold the edge of the exterior curved aluminum over the c channel and make the curve section that transitions from the side to the underbelly. (the lower black piece on my trailer)
Install the aluminum vertical and horizontal studs.
Pull all wiring
Install the exterior skin and interior aluminum (roof and interior top curved sides.)
Install the interior wood wall panel walls, the flat portion of the walls.
Build out the entire interior. All cabinets and shelves are built in place piece by piece.
Everything can be disassembled but it is like a big puzzle sometimes trying to figure out the order of disassembly. Not bad though, pretty accessible with standard tools.
If anyone wants photos of anything in particular let me know. I believe this 1985 trailer is the very last year for the gold sided trailers and this one was built in Sept of 1985.
Old 03-11-2011, 07:27 PM   #26
Vintage Kin
Fort Worth , Texas
Thanks for the description of damage. Not so bad as it might have been. Pleased to know that.
(Very good description of construction; a regular WIKI on SS!)II too was pleased that in removing the bathroom to replace the floor that R&R was as simple as a puzzle.
The 1986 and later trailers are quite different, at least what I've seen. Here are some web album shots of an '86 for sale in mid-2010. The interior is much the same as from early 1980's on, but the exterior construction is such that it appears to be a different trailer.
Have twice seen a two-door late '80's SS with onboard generator built for a disabled customer. The ad never lasts more than 1-2 days.
Old 04-08-2011, 09:00 PM   #27
Cypress , Texas
ETN550,
I just found this thread on the SS. We had the 1979 SS Supreme rocket that was my In-Laws. We found a beauty of a 1989 Avion 34V and sold the SS. I t was in great shape and these old trailers were built like a tank compared to todays junk.
We hated to see the SS leave, but we needed more room. The SS was strictly a 2 person trailer, plus we had 2 schnauzers and a parrot to travel with us.
The Avion is another well built silver beauty. Our approach on the Avion has been to make it functional and not worry so much about original.
You are doing a great job on the SS.
Ken
1989 Avion 34V
TXiceman is offline   Reply With Quote
Old 04-09-2011, 01:11 PM   #28
I have been pretty busy and will have some more pictures to load shortly.
The Avions are real nice too. Very well built. I like the 30 footer Avions.
I'm going to be working aggressively on my trailer in the next 2 months to get the rear bedroom done.
Old 04-30-2011, 10:14 PM   #29
Rewiring
While I had the interior walls off i did some rewiring. I added some lamp circuits and cable tv jack locations.
Old 04-30-2011, 10:28 PM   #30
Isolated Rear Stabilizer Jack Screws
This is one of those little projects that gets done because it just needs to be better than it is.
Situation: On this 1985 trailer with the fiberglass lower corner pieces there are holes in the bodywork that access the jack screw for the rear stabilizers. These exterior holes are a great home for rodents and wasp nests as I found out
Exterior views of the way it was:
View of the large interior area under the subfloor after i cleaned it out. There was fiberglass batt insulation torn loose from rodents. The insulation was about 3 inches but the space is about 8 inches deep.
I enlarged the exterior holes in the fiberglass and inserted aluminum tubes I cut to length. Then I sprayed Great Stuff foam around the tubes to seal everything and support the tubes.
Now the hole is limited to the jack screw and has little space for anything else and can be cleaned out if needed from the outside. I still need to trim the tubes flush and will do this when I prep the lower corners for paint shortly.
Old 04-30-2011, 10:46 PM   #31
Insulating the Floor and Walls
I replaced the fiberglass batt with rigid styrofoam insulation. This was a really fun job and went real fast and real easy and great results. I used two types of foam insulation. 2 inch and 3/4 inch. In my pics the white board is the 2 inch and the green board is the 3/4 inch. For the floor and areas where there was no wiring the 2 inch was used. For the wall sections where there was wiring I used a 3/4 panel between the outer wall and the wires and then another 3/4 panel between the wires and the inner wall. This allows for a 1/2 inch gap in the middle of the wall for the wires to run. I used 3 inch drywall screws to hold the 1/2 inch gap between the foam panels by screwing the screws in while holding the spacing on the panels. The panes have gaps around their perimeter where the great stuff foam is sprayed in to form a bond and virtually airtight seal. After the Great Stuff set up and finished expanding and got hard it was easily trimmed with a steak knife, flush with the Aluminum wall studs.
Panels cut to size
Foam in with drywall screws temporarily holding the panels in place
Green board showing the temporary drywall screws used to maintain the spacing between the panels.
Foam applied.
Foam fully set up.
Easy trim flush with a steak knife.
Trimmed with steak knife and showing new fiberglass batt used in the corner due to all the cables and wire.
Old 04-30-2011, 10:58 PM   #32
Don't use 3003 Aluminum Unless it is Polished!
I bought some 0.040" 3000 series aluminum sheet to use as the interior wall panels. Well, it came mill finish in 4 x 10 sheets and was fairly shiney. Too shiney and it scratched very very easily. I was sold this alloy because the sales guy said anythng harder would not bend or fabricate easily.
So after installing one panel in the bedroom I realized it was not going to work as it was too shiney and was scratched from handling it during inatallation.
so I bought some industrial aluminum brightner to turn it white and take the shine off of it. I reasoned this would also hide scratches. After putting on full chemical suit, goggles, face shield, and double neoprene cuff length gloves I carefully washed several panels and was pleased with the results. However, Hydroflouric acid is too scarey for me.
I mounted the acid washed panel and to my amazement instead of scratching it became polished from handling. I could literally shine it up by rubbing my fingers on it.
So off it came and expensive lesson learned and time wasted.
Back to square one.
Low an behold I found some 5005 Anodized sheet out of Orlando! I ordered 10 sheets of 4 x 10ft and waited for it to arrive.
And here it is!
Old 04-30-2011, 11:08 PM   #33
Sliding Door Latch
While I was waiting for my 5005 Anodized to arrive I fixed another problem. The sliding bath door was held open only by a plastic stud and grommet arrangement. It would not stay open so when I pulled the trailer and accelerated and braked the door would open and close violently. This action destroyed the stops and tore the door off of its hangers.
So I made a latch out of a stainless baggage door catch and flush mounted it in the door. I make a hefty catch out of some angle.
And yes you see it riveted to wood paneling. I did some experiments and the 3/16 aluminum rivet has excellent holding power in the wood. this revelation leads to a whole bunch of riveteting to wood which will be shown next. I like the look of the aluminum and the wood.
Here's the latch I made:
Old 05-01-2011, 09:21 AM   #34
Vintage Kin
Fort Worth , Texas
I especially like the stabilizer enclosures. And, we (wife and I) like the look of the new latch (interior rivet work). Thanks for the haz-mat testing. Glad the insulation job has gone smoothly. Can't remember the what the sub-flooring will be: Marine-grade. Advantech? Other?
Old 05-03-2011, 09:51 PM   #35
Interior Walls Go Back In
Here are some pics of how I put the walls back. One thing to note is that since I did not take the shell off the frame I had to restore the structural integrity of tieing the shell to the frame. Since the subfloor is sandwiched between the c channel that holds the shell and the frame and the subfloor is rotted then the structure must be tied together. Cutting out the subfloor leaves only a rotted strip of subfloor under the c channel to support the shell. I believe my solution solves three problems at once. 1) By not having to do a shell off subfloor I can now do sections at a time. This year I am doing the rear, next year the front, then the middle, all while being able to take a break and use the camper. 2) My interior siding panels (for the most part) are lapped like shingles on a roof so any leakage ending up inside the walls cannot escape. 3) The walls now extend below the subfloor so water cannot get on the subfloor.
I used aluminum angle to create the structural support for the wall to frame and now the subfloor takes no part in supporting the walls.
These nibblers worked great to cut the aluminum
I used chalk lines and reference marks on tape to locate the beams behind the panels. this proved to work well as I did not miss any of the beams when riveting the wall panels.
I riveted the aluminum to the wall and then cut out the window openings. the nibblers went right up to the edge flush. Corners were a little tricky but all in all each window took maybe 15 - 20 minutes to cut in.
Showing how the walls extend below the subfloor. BTW subfloor had to be 19/32 to match the existing that was not removed so my choices were limited. I used a fir plywood sanded both sides and primed and painted it all over.
Showing wall lap for drainage and aluminum angle used for wall to frame support.
Showing subfloor undercut to match the thickness of the angle.
All walls done! The curves were extremely tricky due to the rear wall being angled from vertical.
Old 05-03-2011, 10:05 PM   #36
Cutting a Hole in a Wall
I'm almost caught up with my documentation. Here is an interesting project that I am pleased with the results. My camper did not get good A/C to the rear due to the center bath narrow hall, and wall separating the rear room from the rest. Across from the bath is a nice dresser arrangement but it is walled on both sides. I decided to open it up to get better airflow and make the space seem bigger. I will put blinds or shutters over the hole to allow for eithr open or shut.
Dresser before with wall separating bedroom on right.
Rear bedroom looking forward from the trunk space. Subject wall is on the right side.
Cut out the hole. The wall is two layers of panneling separated by pine wood spacers all glued together. Light and strong but weaker when cut.
Framed in with aluminum on the dresser side.
Finished framed on the bedroom side.
Opposite side wall in the bedroom laminated aluminum over existing paneling.
Old 05-03-2011, 10:13 PM   #37
Question Question on Flooring Stapler
After some research I have settled on thin 5/16 inch thick x 2-1/4 inch wide solid teak flooring. This flooring needs to be put down with an 18 gage flooring stapler. The Bynford $79 chinese made stapler is the choice and gets good reviews but is not available anywhere at the moment. Next best price is a commercial Bostich or equal for $170 or better.
Any leads on what is my best stapler option at this time? I prefer to buy versus rent the stapler as I am only doing the rear now but have enough flooring to do the whole camper in stages.
Why teak? For me because it looks good, wears well, good water resistance, does not change dimension much with moisture, 5/16 is thin and does not add too much weight or detract from the height. Should be about the same as the carpet and pad. Not a bad thing that Lumber Liquidators sold it to me for $1.59 per sqft either
I'm thinking of laying it at a 45 angle.
Old 05-08-2011, 10:45 PM   #38
chowman2011's Avatar
Leadville(for now) , Colorado
I have thoroughly appreciated your posts!! I have a '77 SS Supreme Rocket Continental 2800(I believe)...28' would include the hitch length.
Anywho--working on some restoration and getting it functional again...Your Electrical in VERY Interesting to Me!
Cureently working on the interior and getting major systems back online...More to Come....and I HAVE MANY inquiries as to ensuring a reliable/pleasurable and long term enjoyment with this Silver Lady!
Great Work--and I look forward to My Part here and Everyone in the Realm of Silver(Tin) Travel Trailers!!
Cheers!!
chowman2011 is offline   Reply With Quote
Old 05-08-2011, 10:55 PM   #39
Very Nice Work!! I am fortunate...No need to re-do these aspects at this time--YET, tear out and replacement can be quicker in some cases...I choose the 'refurbish' approach to the front living area and kitchen--FOR NOW....Yet still have the Major Appliances and Some Extior Maintenance to do....
Old 05-09-2011, 09:57 AM   #40
'77 SIlver Streak "refurbish"
Here are some initial pictures of the front area and kitchen "refurbish".
Silver Streak project SilverHoot Vintage Kin 37 05-08-2011 11:22 PM
silver streak mickeymoose Vintage Kin 6 05-09-2009 11:57 AM
Silver streak Pepsi Vintage Kin 23 03-10-2008 08:49 PM
Silver Streak - Need Your Thoughts mwinter Vintage Kin 52 03-03-2008 11:59 AM
Silver Streak Ultradog Vintage Kin 3 12-31-2006 01:12 PM
