Old 03-02-2021, 10:25 AM   #1
2019 25' Flying Cloud
Kalamazoo , Michigan
Identify Vintage Airstream
Hello, I'm trying to identify this model. Think it might be a Clipper? Any help would be appreciated. Thanks!Click image for larger version
Name:	Vintage Airstream.jpg
JMatson1111 is offline   Reply With Quote
Old 03-02-2021, 12:41 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I do not believe it is an Airstream, possibly a Curtis Wright, not sure. I remember a lecture I attended by the previous historian for the VAC and he stated that Airstream windows do not cut across the rivet lines of the segment, but run parallel to the seams.
Richard
Old 03-03-2021, 07:55 PM   #3
Odessa , Texas
It's the back end of a 1930s Bowlus Road Chief. Maybe a 1935?
The original models from 1934-1936 had some with rear windows that crossed the rivet lines. That one looks like it had the oval rear windows covered with aluminum sheet at some point. You can see a 1935 here with the rounded windows.
Check out the third pic down on this page for a similar one and a bit more background. They started making them again in 2015. I have a 2020 model and it's amazing. https://bowlus.com/the-story-of-bowl...ravel-trailer/
Yankee Hobo is offline   Reply With Quote
Old 03-05-2021, 10:00 AM   #4
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
It is hard to make any conclusions from that single photo, built it appears to be reasonably consistent with a 1934 to 1936 Bowlus (realistically 1935 or 1936 since Bowlus did not produce his first trailer until November 1934), or possibly a 1936-39 Airstream Clipper. Off hand I lean more toward the Bowlus because of the rear windows (which have been modified). Side or front photos will allow it to be identified more posirively.
It definitely is not a 1947-49 Curtis Wright Clipper.
I should also mention that at least a couple non-Bowlus, non-Aistream riveted aluminum "copy cat" trailers from the 1930s are known to exist, so that also remains a possibility.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Help identify this vintage Land Yacht and its value? Berdesigner Trailer Values 0 08-13-2013 04:17 PM
Identify vintage wheel cover lbell Exterior Restoration Forum 10 12-01-2012 07:01 PM
Help me identify my 1956 Airstream please! Ravyn1711 Airstream History 11 11-07-2010 12:34 PM
Airstream or not? Please help IDENTIFY! fcavolijr General Motorhome Topics 20 09-22-2009 10:49 AM
Help identify airstream skibender Off Topic Forum 11 01-13-2006 07:36 PM
