They’re probably the horizontal stringers that go between the ribs. Normally they’re not attached to the ribs, just bucked to the exterior skin and the interior skin is pop riveted to those. From what I understand, in aircraft they’re attached to the vertical ribs, in Airstreams they’re not. In my 55 I attached them to the verticals. You have C-channel around the windows, some are segments and some are the vertical ribs. After the interior skin is in, you have 90 degree pieces around the window trim the same gauge as the interior skin. That’s my best guess. Good luck, Bubba
