I have a damaged piece of paneling in a ceiling bin that I would like to replace. The panel looks to be glued and screwed. See picts. Has anybody done this replacement?
If so, what is the procedure?
If there are screw visible I would remove them. If the panel is glued to the framing, take a putty knife and tap on the inside of the head locker between the panel and frame. Our 66 model originally has red oak. There were no head lockers in ours when we got it. We solicited exact dimensions and pictures to replicate the original. Shouldn’t be that bad. Is the vent pipe penetration at the roof leaking and trickling down the ABS to the head locker? Good luck
