Old 06-17-2019, 05:21 PM   #1
1966 17' Caravel
The Woodlands , Texas
Anyone have a Dometic Cool Cat Under Bench AC?
Hi!
Looking to install an AC in our 17 foot '66 Caravel. Really do not want a rooftop AC. Came across the Dometic Cool Cat and would love to hear if anyone has pros, cons or opinions on it. Thanks!!
lisasammy is offline   Reply With Quote
Old 07-06-2019, 08:31 PM   #2
rosyriveter
1966 24' Tradewind
1959 18' Traveler
Winchester , Virginia
Dometic Cool Cat heatpump
We installed a Dometic cool cat heat pump under one of our twin beds in our 1966 Tradewind restoration. The key issue was distributing the air throughout the trailer. We had a galvanized distribution box fabricated that was installed under the subfloor between frame crosspieces that has 2 inch high compression tubing going from it to various vents through the floor. There is a 15in x 4in return duct in the bathroom closet that feeds under the bulkhead back to the unit. If you wan to see pictures you can go to my restoration blog at annieairstreamrestoration.blogspot.com. It works great for us, providing our AC and heat down to 40 degrees when the thermostat automatically kicks it off and switches to our gas furnace. However, from what I understand from the local Camping World guy that sold us the unit, it doesn't work nearly as well if it is not ducted. It was also a bit involved to design and install so it would work properly, including have to cut a hole in the side of the trailer for the exhaust and intake. We had a compartment door that matched our other doors made so it would not be obvious when we were not using the unit.
annieairstrm is offline   Reply With Quote
16ft Sport-Valves under the kitchen bench klogan1010 Plumbing - Systems & Fixtures 0 05-28-2016 08:42 AM
I have put a TV on the wall behind the bench seat and table I need to get the antenna Trident Land Yacht/Legacy Motorhomes 34 09-07-2015 08:47 AM
Clicking sound under bench - 23' ASchwager Batteries, Univolts, Converters & Inverters 6 05-22-2014 11:38 PM
Under Bench AC with Heat unit truckasaurus Furnaces, Heaters, Fireplaces & Air Conditioning 1 11-24-2011 08:51 PM
Dometic Duo-Therm "Cool Cat" heat pump/AC unit?? PA BAMBI II Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-19-2010 08:52 PM
