Old 03-08-2008, 06:58 AM   #21
Wayward's Avatar
Broadway , North Carolina
Very interesting thread you started Jurjen! The Eagle was one of those vehcles that was ahead of it's time - I am gald to see you're keeping one the road.
If that ad photo is the inspiration for your next caravan setup, I hope you are successful!
Keep us posted and, when you get the Eagle/Airstream rig on the road, please post a picture in front of the Kinderdijk!
.........Scott
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
Old 03-08-2008, 07:21 AM   #22
Wayward's Avatar
Originally Posted by Stephan
Hello Jurjen
Der Eagle sollte mit einem kleineren Airstream (max.22') keine Probleme haben.
Die Amerikanischen Wohnwagen der 70er haben aber eine viel höhere Stützlast als dein Dethleffs.
Grüsse aus der Schweiz
for those who had a little trouble reading that post
" Consider Tongue Weight!
The Eagle should not have a problem with a smaller Airstream (max.22 '). However, the American trailers of the 70's have a much higher trailer hitch tongue weight than your Dethleffs. Greetings from Switzerland"
2006 Safari SE FB
Broadway, NC
Old 03-08-2008, 07:35 AM   #23
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 196
AMC Eagle towing Airstream
I suspect, but haven't been able to find photographic proof that the coach being "towed" by the Eagle is a 1980 Caravelle 22'. My theory is based upon the presumption that the 1980 Caravelles were based upon the 1977-79 Argosy Minuets whose production ceased in 1979. My notes indicate that the coaches had the narrow body of the Minuets and virtually identical floorplans (which the window arrangement on the coach in question seems to point toward). The photo that I have attached below is one of the 1977 6.7 Metre Argosy Minuet and was posted by Forums member Loudruff --
While not exactly identical in window arrangement I sense some similarity, and AMC products were often used in advertising the Minuet products such as the AMC Pacer with the 6.0 Metre Minuet in the scan below:
I have been able to locate photos of the 20' and 14' Caravelles, but not any of the 22' Caravelle.
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 03-08-2008, 08:33 AM   #24
pcasa's Avatar
1966 17' Caravel
Dallas , Texas
Neato!
Good job Jurjen for seeking these answers! I too think it's very cool to get this rig back on the road. The AMC Eagle was ahead of its time and inspired a number of current vehicles including my baby, an Audi allroad which I'm convinced will be my tow vehicle. Good luck to you and keep us posted!
pcasa is offline   Reply With Quote
Old 03-08-2008, 12:13 PM   #25
Buitenpost , Frl
I like the picture with the AMC Pacer very much!
I found a nice link showing the Caravelle:
Fred's Airstream Archives - 1980 Trailer Models
Could well be that this trailer was used for the ad.
jurjen is offline   Reply With Quote
War Eagle! nilesrob Off Topic Forum 4 01-05-2011 02:13 PM
Winter Trip recomendation: Eagle viewing Boondocker On The Road... 36 12-06-2007 04:07 PM
Towing My Airstream Pinkerton 1970-79 Tradewind 10 04-27-2007 06:08 AM
double/eagle double/eagle Member Introductions 1 09-15-2006 12:54 PM
Eagle Lake, California ?? myoung On The Road... 7 07-18-2006 12:01 PM
