You are wise to simply replace the belly pan. You gotta jack up the trailer preferably on a hard surface and make sure it is stable. Your vintage Overlander belly pan does wrap around the outriggers and is attached to the C channel. I have replaced 4 belly pan in my Airstream life. It is hard work, but very doable. And it give you the opportunity to rake out all the old smelly fiberglass insulation, examine the frame and make any repairs needed, brush off any rust and paint the frame, and then maybe install proper waste water tanks. We call it jumping down a rabbit hole as one thing leads to another.
Here are some photos of my 66 Trade Wind 24' belly pan project. Just to give you an idea of what it looks like under there. Belly pan aluminum is 5052 and available from Kansas City Air Parts. Look them up in the internet. They are a good supplier in my view.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
