11-20-2022, 05:07 PM
#961
1971 21' Globetrotter
Arvada
I picked up the screen frames the other day and started working on them. On the back side of the frames is a lip that is .125 high. If the mounting hardware is tightened to tight it deforms the frames quite a bit. I made a bunch of .125 spacer blocks and am in the process of riveting them on.
Sent from my Lenovo YT3-X90F using Airstream Forums mobile app
11-20-2022, 06:42 PM
#962
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Good idea. I guess I tolerated that little bit of deformation and for some reason my screen frames were attached with sheet metal screws. But your Globetrotter is built to aircraft standards.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
11-20-2022, 07:32 PM
#963
Arvada
I will be using the top 3 fastener locations on the screen frames for window shade mounts. I will bend them up when my wife tells me which style and type I want to install
I have no sheet metal screws installed on the trailer.
11-29-2022, 07:57 PM
#964
Sunset Beach
, North Carolina
window shades
Have you ever thought about building shade guides on each side of the window that would fill the curve gap, so there is complete privacy? I have been thinking about fabricating curved guides that would mount to the wall and provide a curved channel that the shade would follow to the bottom of the window. I would add a topper that I could attach a curtain rod to.
the shrinker/stretcher might be helpful here
Thoughts?
11-30-2022, 07:19 AM
#965
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
Thoughts?
I have been using aluminum magnets sewn into the edges of our fabric curtains. They are a little expensive, but are very handy to get a nice tight fit to the window frame.
Zep
11-30-2022, 08:03 AM
#966
1967 17' Caravel
Oak Creek
Are the aluminum magnets manufactured from Unobtainium?
11-30-2022, 08:11 AM
#967
1972 31' Sovereign
Lexington
I just made side curtains for our windows that are fastened at the bottom to hold the blinds against the windows and cover the sides of the blinds. Works for us. Down side is that after 12 years they're starting to bleach out. I may need to make new ones....
And apparently there is such a thing as aluminum magnets.... the unobtanium would be the money to buy them!
Kay
11-30-2022, 12:06 PM
#968
Arvada
Thoughts?
That's a good idea but I don't think a shrinker stretcher would be needed, just three pieces of aluminum with the center piece narrower for the shade to slide down. It would be a lot of work but doable.
11-30-2022, 12:07 PM
#969
Arvada
Zep
I'll have to check stock at McMaster Carr, do you have a part number?
11-30-2022, 06:50 PM
#970
1986 34' Limited
1975 27' Overlander
Conifer
Airstream made a molded plastic shade guide and position holder for the galley window back in the mid seventies. It solved the curve window problem, but was a rather clunky looking thing. I bet it was an idea from the same department who had the oven in the wall idea. I left it off in my renovation.
David
12-01-2022, 05:28 AM
#971
1973 23' Safari
1977 23' Safari
Palmer Lake
Unobtainium. I saved some from the days when I worked at Area 51. There was quite a bit of it in the structure of that flying saucer that we brought in from Roswell for testing.
Zep
(PS: sorry for the hijack, I couldn't resist)
01-20-2023, 02:40 PM
#972
Arvada
I picked up the screen frames from powder coat. They did a really good job and they look fantastic.
01-21-2023, 05:11 AM
#973
2004 28' International CCD
1948 22' Liner
1963 22' Safari
Oakland
Those do look really nice! Can't wait to see them installed.
02-01-2023, 04:03 PM
#974
Arvada
Router sled is complete, I have an entire American Elm that has been slabbed into 6 quarter. I plan on having live edge countertop and dinette table. More to come on this so don't slam me on wood movement and weight.
02-02-2023, 07:53 AM
#975
1972 31' Sovereign
Lexington
Wow! That is the best router sled I have ever seen! I'm thinking you made it rather than bought it?
Can I have it after you've flattened your slabs? But then, I'd have to build another addition to my workshop...
Chris
02-02-2023, 08:39 AM
#976
Arvada
Yes, I made it using linear rails I obtained online at Vevor.com
02-03-2023, 07:59 AM
#977
1972 31' Sovereign
Lexington
Thanks Kip! Very cool website. Bookmarked now.
Chris
05-16-2023, 02:16 PM
#978
Arvada
05-17-2023, 03:03 PM
#979
1973 23' Safari
1977 23' Safari
Palmer Lake
I need a support pan for my new gray tank in the '77 Safari. I may have to visit and have a chat.
BTW, we had our awning unfurl completely out in Kansas when the crosswind was 40 kts. But the hold downs never came loose. When we stopped, the fabric mostly rolled itself back into the shroud. We managed to keep it tucked in with 200 yards of duct tape...
05-17-2023, 08:30 PM
#980
Arvada
I just bought the aluminum to make my grey tank pans. I going to use .063 6061-T6. But hold on to your wallet, aluminum prices have gone through the roof.
