Old 06-09-2020, 08:07 PM   #1
2018 Basecamp
Delta , BC
Truma ignition issue
Hi all,
our 2018 basecamp has had some recent truma CP plus hot water issues...
occasionally our hot water won't ignite when we try it. we were out two weeks ago and it worked perfectly. last week, i couldn't get it to light.
this happened last year as well, and after much research, i vacuumed out the exhaust vent and everything seemed to be fixed (bugs and spiders get in there and nest.)
after trying everything i could think of while away- generator power, purging lines, different tanks, vacuuming out the exhaust, etc- i arrived home and tried
it again... no luck. so i used my large shop vac to hopefully clear whatever may be in there, and it worked! i made sure by disconnecting house power and trying a few more times, and it worked fine. i shut it off for the night.
so todave.... i could not get it to ignite no matter what i did, and i tried literally everything (no, i haven't quite called truma service)
there were a couple of times when it would ignite, but not stay lit once the cycle was over. i'm stumped!!
anyone else dealt with this?!
thx,
dave
davewear is offline   Reply With Quote
Old 06-10-2020, 08:49 AM   #2
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Originally Posted by davewear View Post
Hi all,
thx,
dave
Hi davewear,*
We're very sorry to learn about the issue you are having. Please send us a direct message with your contact information, email and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 06-11-2020, 09:45 AM   #3
2018 Basecamp
Delta , BC
Solved!
well, it got solved...
i ended up trying the "quick open" method for opening my propane tanks (i'd been trying the "open slow" method), and then running the stove burners for a fair while, which i found as a tip on the web.
i also tapped the regulator a few times, so that could be part of it...
seems i must've had air in the lines, and it wasn't purging itself properly.
anyhow, if it happens again, i now have a few versions of what to do.
get out and enjoy!
dave from davewear.com
On trip - need help with key/ignition issue AirstreamGT Sprinter and B-van Forum 60 08-31-2019 08:09 PM
Truma Screen Issue? Fiala06 Base Camp 2 05-03-2019 08:44 PM
Ignition Switch Issue freedombro Mechanics Corner - Engines, Transmission & More... 18 06-16-2018 06:19 AM
Instead of a Generator, Truma launches VeGA nmayer1 Electrical - Systems, Generators, Batteries & Solar 2 11-15-2012 08:54 AM
Are you feeling like Sherlock? Strange ignition issue, need advice scottf3334 Mechanics Corner - Engines, Transmission & More... 15 08-28-2009 08:45 PM
