Old 05-26-2022, 09:18 AM   #1
Sydney , Para
Transporting generator in your Basecamp?
Does/Has anyone transported their generator in their Basecamp? I have a heavy one (Champion 4500) and would like to secure it inside the trailer as my TV payload is limited.
Was looking to use my straps to tie the generator down using the floor hooks closest to the center of the Basecamp. Then adding some cushions to keeping it from bumping side to side.
Has anyone tried this and have some feedback? Im afraid i'm overlooking something and with the generator being about 100lbs, a small mistake could be devastating.
spoonierme is offline   Reply With Quote
Old 05-29-2022, 08:02 AM   #2
2020 16' Basecamp
Louisville , Kentucky
Yes
We travel with two Honda eu2200 in our base camp from time to time. We set them on a rubber backed rug to prevent the rubber feet from discoloring the floor. They really donít move around much. And have never had an issue.
Rolind is offline   Reply With Quote
Old 06-01-2022, 09:14 AM   #3
Sydney , Para
Thanks for the feedback. Granted every situation is different, I do feel a bit more at ease traveling with the generator in the trailer.
Old 06-16-2022, 09:16 PM   #4
Mercerme's Avatar
2021 16' Basecamp
Georgetown , Alabama
I plan on transporting my 3400 that way as well (96lbs)
Mercerme is online now   Reply With Quote
Old 06-16-2022, 09:28 PM   #5
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
If your champion has the ability to run on propane, don’t run gas through it. You won’t have any gas odors to deal with when storing inside.
- Stewart
s1000pre is offline   Reply With Quote
Old 06-17-2022, 04:14 AM   #6
Mercerme's Avatar
2021 16' Basecamp
Originally Posted by s1000pre View Post
If your champion has the ability to run on propane, donít run gas through it. You wonít have any gas odors to deal with when storing inside.
Propane only used
Old 06-17-2022, 08:43 AM   #7
Mollysdad's Avatar
The 4500 is roughly 24" x 18" x 20"H.
At 103# it's not likely to be lifted into a storage container.
So I'd make a plywood base a bit narrower than the door and cover the bottom in "Non Slip" rubber mat, then strap the beast to that. The chances of a tip over while transporting is greatly reduced. Plus any oil dribble would be contained there.
I give you bonus points for a Basecamp with a 4500 generator.
"Anything worth doing is worth overdoing" -- Mick Jagger.
Help! Transporting gasoline for generator,where, Suburban and AS, no open truck. airdreamers On The Road... 37 11-03-2014 09:33 AM
Recharging Batteries/ transporting portbale generator boblomquist Generators & Solar Power 5 05-24-2013 03:56 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
