Originally Posted by BayouBiker
The tank heaters will protect the tanks, but won't keep the interior warm enough to prevent the pipes from freezing. For that you will need about 100 -500 watts additional depending on how cold it gets. One or two portable electric heaters set at the low setting will do the job unless it drops below 15 or so.
Thanks Brian - good suggestion on a small space heater, the basecamp is a small trailer so the interior will heat up quick even w a small unit, I experienced this in my very first outing w a Safari16 I rented to give the experience a try, took like 3 minutes to be toasty with the smallest portable heater you can imagine. I know the tank heaters run on
12 volt, but do they also use propane? I assume they do.. perhaps a good investment would be some some gauges for the propane tanks so I can get a feel for how much propane they are using. If I'm wrong about the propane let me know
