Old 01-18-2024, 04:30 PM   #1
kfh
2024 20' Basecamp
Camano Island , Washington
SeeLevel II battery monitor?
Greetings! Just purchased a 2024 Basecamp 20X REI and noticed that the SeeLevel II battery/tank monitor is way off on its battery reading compared to the Victron monitor. I actually would only rely on the Victron anyway but was curious if others have had this same issue. The Victron has the batteries (Battleborn lithiums) at 13.6 volts or 100% The SeeLevel is displaying 12.6. Quite a huge discrepancy. Not sure if the SeeLevel is made to read lithium batteries or is not calibrated. Any input would be appreciated.
Cheers!
kfh is offline   Reply With Quote
Old 01-18-2024, 10:11 PM   #2
dznf0g's Avatar
Oswego , Illinois
I seem to recall, in the deep recesses of my memory, that the install instructions say that if it is hooked up out of a specific sequence when it is installed, the volt meter will br damaged. I'd call seelevel and discuss with them. My info is some 9 or 10 years old and things may have changed.
-Rich-
Seelevel II Tank monitor- reads 0 for Black tank waninae39 Electronics & Connectivity 2 08-07-2020 04:00 PM
SeeLevel monitor wbrisett Electrical - Systems, Generators, Batteries & Solar 1 06-17-2017 07:12 AM
SeeLevel II Battery Monitor Teton Stream Electrical - Systems, Generators, Batteries & Solar 5 02-05-2017 08:18 PM
Can you calibrate a SeeLevel Monitor? SeaLevel Plumbing - Systems & Fixtures 7 01-26-2016 09:20 PM
Seelevel 700 series monitor from Garnet Robo104 Electrical - Systems, Generators, Batteries & Solar 3 04-28-2015 06:35 PM
