Old 03-15-2020, 06:07 PM   #1
2019 Basecamp
Killeen , Texas
Propane Flow
Hello. I recently purchased a 2019 Basecamp X. My wife and I took it out for the first time and now there is no propane flowing to any of the appliances (Truma, stove, or fridge). I’m getting a gas pressure regulator fault on the Truma. I have turned off the LPG bottles, unscrewed the auto regulator. Tried bleeding the lines. Nothing is working. Any help or suggestions would be awesome!
SawcBasecamp is offline   Reply With Quote
Old 03-15-2020, 07:57 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Check you have propane in the bottles. Remove the propane lines coming from the regulator to the trailer. Turn on the propane bottles slowly. If you have no propane coming out of the regulator you have a regulator proplem.
Old 03-16-2020, 06:22 AM   #3
2019 Basecamp
Killeen , Texas
Awesome! Thank you. I’ll try that today and let you all know.
Old 03-16-2020, 06:52 AM   #4
2018 25' International
Slidell , Louisiana
The regulator has a feature that prevents flow if the downstream line is leaking excessively. It sometimes trips. There are lots of threads about this. Sometimes they can be tricky to get the regulator to reset.
If the advice given does not work, sometimes it helps to shut the tanks and remove the tank connections and use a small rod to bleed off any remaining pressure. Then follow the advice given again.
Brian
Old 03-16-2020, 07:40 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
No...that will not determine 'flow'.
You may have a stuck OPD valve.
Turn the cylinder off.
Remove, turn it upside down, then roll it slowly on the ground, reinstall and try it.
"OPD Valve Design
OPD valve looking at connection
The design of the OPD valve is such that turning the cylinder service valve handwheel will not produce any effect if the cylinder is not hooked up to an appliance. In other words, a connection must be made between the appliance hose end and the cylinders service valve. The inside of the OPD valve is engineered to only allow propane in or out if the internal valve is actuated by being depressed. This OPD valve feature adds additional safety in case the handwheel is turned, opening the valve. For this reason, OPD equipped cylinders will not allow gas out of the cylinder when opened. The same is true for industrial forklift cylinders."
If that doesn't work you may have a regulator problem.
Good luck...👍
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."Molly Ivins
“Growing Old…being able to think about the things you can no longer remember.” RLC
"Never tow faster than your Guardian Angel can Fly"
Tahawus....🌥
Old 03-17-2020, 07:43 AM   #6
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi SawcBasecamp,*
We're sorry to learn about the issue you are having. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 03-17-2020, 11:29 AM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
I was wondering if that might not be the case.
Old 03-17-2020, 04:58 PM   #8
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Sometimes the problem is the pigtail coming from the regulator to the tank. Had that problem. Tank was full, no gas coming from the tank. I replaced the pig tail (which I had just purchased new) with another and found that the gas started flowing again. Problem was a defective pigtail.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-23-2020, 08:37 AM   #9
2019 Basecamp
Killeen , Texas
Update: I replaced both pigtails and regulator and I have great propane flow. The pigtails were brittle. I think someone used armor all on them before I got it. I’m convinced it was the regulator! Thank for everyone’s help!
No propane flow dapolrbear Sprinter and B-van Forum 44 06-25-2018 09:48 AM
Here's the problem, what's the diagnosis: propane flow eubank LP Gas, Piping, Tanks & Regulators 23 09-12-2012 08:25 PM
Flow Thru Exhaust and Muffler LKappenman Mechanics Corner - Engines, Transmission & More... 17 09-22-2009 11:29 AM
Water flow question... Sneakinup Waste Systems, Tanks & Totes 1 05-19-2004 06:20 PM
No water flow Michael W Plumbing - Systems & Fixtures 4 10-12-2003 08:26 PM
