Old 12-27-2024, 09:32 PM   #1
2025 20' Basecamp
Sewickley , Pennsylvania
Mounting a TV in Basecamp
I want to install a TV to stream movies. Since locations are limited, I thought this would be a good spot. It would be on a full-motion mount so I could still access the cubbies.
Since I haven't bought the Basecamp yet, can anyone tell me how wide the bathroom wall is (see red square)? I heard a 27-inch TV would fit without protruding into the walkway. Is this true?
Lost Rivet is offline   Reply With Quote
Old 12-28-2024, 10:26 PM   #2
2023 16' Basecamp
Creighton , Nebraska
We had the same questions when we got our 16x. We ended up just using a laptop. You might have more options for mounting a tv in your 20’ than we have in our 16’ but we couldn’t imagine a better setup than the laptop.
pfm41 is offline   Reply With Quote
Old 12-29-2024, 08:37 AM   #3
Lon BRISCOE's Avatar
2022 20' Basecamp
Edmonton , AB
I made a suction cup bracket thingy that hangs my tablet from the ceiling then use my Bose blue tooth speakers in the rear upper baskets.
Home theater on a budget.
Lon BRISCOE is offline   Reply With Quote
Old 12-29-2024, 03:26 PM   #4
2025 20' Basecamp
I'll be working full-time from my laptop. So having it double as my TV makes sense, but was hoping to kick back with a screen bigger than 13 inches.
Old 12-29-2024, 03:29 PM   #5
2025 20' Basecamp
I think I'm the only person in the world that doesn't own an iPad. So I did consider a similar setup, but buying an iPad would cost more than buying a small TV. Trying to keep the year long adventure cost down as much as possible.
Old 01-01-2025, 10:14 AM   #6
2023 20' Basecamp
Des Moines , Iowa
We decided to go with a projector. We used command hooks on the right side of the fridge and one to the left of the door, and put up a white shower curtain. Got a cheap projector from a computer recycling store for $25 and enjoy movie time on the big screen.
yesitsmedoug is offline   Reply With Quote
Old 01-01-2025, 02:05 PM   #7
JH1
2024 20' Basecamp
Reno , Nevada
TV mount 20x
We use. A Sea Sucker mount (2 large suction cups with a flexible arm between) to attach a laptop in that same area you pointed out in your photo. We have a 20x.
JH1 is offline   Reply With Quote
Old 01-01-2025, 09:04 PM   #8
2025 20' Basecamp
I've always assumed home projectors have terrible quality as compared to TVs and you have to sit in the dark to enjoy them. Is that not true anymore?
Old 01-01-2025, 09:06 PM   #9
2025 20' Basecamp
Do you know what the width of that wall is?
Old 01-02-2025, 05:28 AM   #10
2022 20' Basecamp
Oro , Ontario
I have seen some Youtube videos where they install an articulating mounting in the same location you have outlined. I am still searching for the best option. I do like the suction mount from the ceiling idea, and since i have a couple of extra suction cups from my Moonshade, i will MacGyver a set up this coming season. Our Current set up is a 27" monitor/tv that I use as a work monitor during the day and a tv at night. We set up on the front table and enjoy tv from the back bed.
murraylangil is offline   Reply With Quote
Old 01-02-2025, 07:43 AM   #11
2023 20' Basecamp
Des Moines , Iowa
Ours is one pulled from a business or class room and is nice and bright with a great picture. Besides it is for casual viewing when we need a little down time while we are out enjoying the travels. Picture quality is great and plenty bright. Also, in the Basecamp, making a dark room is easy any where if needed
To be fair I have never used a "home" or consumer grade projector. I can't say if the quality is up there with those intended for commercial settings.
Old 01-04-2025, 07:30 PM   #12
2025 20' Basecamp
Here's a crazy idea that I'm a little nervous to try because it requires drilling, but may work best!
There are studs behind the aluminum shell. Use a stud finder to see if a stud exits on the wall between the rear door and bathroom wall. If so, double check with Airstream to see if there is any wiring in that area. If you're sure you won't damage any wiring, carefully drill to mount it there. Drill only into the stud and not through the exterior shell obviously.
Otherwise, the original location that I was thinking of on the bathroom wall could only fit at 24-inch TV. Sitting 10-12 feet away would be a bit of an eye strain.
Old 01-05-2025, 03:45 PM   #13
Greenville , South Carolina
My wife and I are shopping Basecamp 20x now, and the main reason is the ability to have a large room feel for a few adults in a small camper for nasty weather. I have thought about a TV on the opposite wall (curbside) in the corner by the door so it could be seen from the dinnette, the kitchen and the bed.
fredsmi is offline   Reply With Quote
Old 01-11-2025, 05:46 PM   #14
2025 20' Basecamp
Wherever you decide to mount it, please post pics! Would love to get some ideas of what can be done.
Old 01-12-2025, 02:42 AM   #15
RMNummi's Avatar
2014 23' International
2022 16' Basecamp
2017 23' International
Saint Petersburg , Florida
Cautionary TV 16
Ok I confess…. I drilled through the BC16X bathroom wall. It don’t take much. I wanted a swing mount vice fixed so…… there I was with my handy dewalt. Now bathroom has a small circular mirror mounted a little low to cough cough shave in shower. In retrospect VHB mount no drill. In my defense I swear I put hands on shower wall and cabinets wall. I too said, what ho mate, there’s a small gap. No studs found. I mounted a 27” LG Oled monitor w Apple TV driving it. Used Sonos Beam as the speaker. My cautionary tale is solely meant to be a “I screwed up (get it)” so you don’t have to. VHB w adhesion promoter would have been just fine in retrospect.
RMNummi
TTs: 14 23D, 22 16X, 17 23FBT, 20 25FBT GT
Prev TVs: 17 MB AMG GL63, 17 Lexus LX570, 20 MB GLE580,
12 Cayenne Turbo, 16 MB GLE400.
RMNummi is offline   Reply With Quote
Old 03-01-2025, 08:31 PM   #16
2023 16' Basecamp
The bathroom wall material is only 1/2" thick. The best thing is remove a screw from a coat hook and use that as a max length gauge.
Basecamp/kvo :: 2017 Airstream Basecamp vkvo Airstream Registry Discussions 0 10-30-2022 12:08 PM
Nomadic Awning 2.0 6.5 with Airstream Basecamp Mounting Kit - Utah Camper Reparadise Airstream Classifieds 0 05-18-2021 12:48 PM
Mounting cellular booster on a Basecamp 20 KelDarBerg Electronics & Connectivity 1 01-05-2021 02:51 PM
