Old 09-23-2023, 10:55 AM   #1
2021 16' Basecamp
Scottsdale , Arizona
Lithium not charging on shore power
We had dealership upgrade our 2021 Basecamp 16x to 2 lithium batteries. While traveling and not hooking up we always had 97-100% charge. Weíve been in a campground with shore power and watched the charge slowly go down each day we are plugged in to now 60% after 7 days. Even with being gone most of day and not running anything outside of fridge, I look at my victron app and see power use but no charge coming in. Does lithium only charge and work off grid? If so why is it reducing when plugged in? Do you think the dealership didnít make some needed connection? Granted we are in northwest and itís been a little cloudy. We are low power users and even use a small Bluetti to charge iPads and phones.
2Rvss is offline   Reply With Quote
Old 09-23-2023, 11:43 AM   #2
2018 27' Globetrotter
Mooresville , North Carolina
The converter should charge the batteries. Check to make sure the breaker for the converter is not switched off as Iíve had that occurs before. Iím sure others will chime in to advise of other ways to see if current is flowing to/from converter.
The solar should charge even if converter isnít unless there is too much cloud cover.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
GOUSC is online now   Reply With Quote
Old 09-23-2023, 12:47 PM   #3
Trailer Sold, Waving
Acheron2010's Avatar
2019 26' Flying Cloud
Stettler , Alberta
check fuses on that converter also
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 09-23-2023, 06:55 PM   #4
1988 32' Excella
Robbinsville , New Jersey
Was the converter ever changed to lithium setting?
Old 09-23-2023, 11:12 PM   #5
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Is this a new lithium setup? Has it ever worked to charge from shore power?
Without doubt, you should be able to charge from shore power.
Richard
11018
richard5933 is offline   Reply With Quote
Old 09-24-2023, 11:54 AM   #6
2018 16' Sport
St. Louis , Missouri
If you have solar, you don’t need a lithium converter. It should charge the battery to 80-85%. Solar will charge it the rest of the way.
In any case you should not be losing charge while on shore power.
Sport 16 STL is offline   Reply With Quote
Old 09-24-2023, 07:22 PM   #7
2022 30' Classic
Cohoes , NY
If fuses and breakers are good, check output voltage from the terminals on the converter. If those are showing proper voltage, then check for loose connections. A clamp-on amp meter can help diagnose if thereís any current flowing from the converter to your panel box. If no current is detected, then thereís likely a loose wire somewhere. Mine was on the negative cable where it ties into the negative bus bar for the whole trailer.
Joey Joe is offline   Reply With Quote
Old 09-25-2023, 07:36 AM   #8
2021 16' Basecamp
Thank you all for information as I was not sure. I will take it back to dealership to fix but I know now what it should do. Back on road and off grid and on first day of travel even with clouds and rain charged back from 62 to 73% so know the solar charging works.
Old 09-25-2023, 08:45 AM   #9
2008 23' Safari SE
Pasco , Washington
Ditto on the loose wire check. Found one when the dealer installed the first 2 Li batteries and 2 loose wires when they installed the 3rd. Needless to say, we were not happy as we paid the Airstream premium for the Battleborns and got less than premium service. All are working well now that the problem is fixed so glad we made the upgrade. Also, ended up switching from a WFCO "AD" that wasn't auto detecting to a Progressive Dynamics and that significantly improved the charge speed whether on solar or shore power.
ckronvall is offline   Reply With Quote
Old 09-26-2023, 07:01 AM   #10
2016 16' Sport
Miami , Florida
How could the progressive dynamic converter improve the charge speed from solar?
Shiny16 is offline   Reply With Quote
Old 09-26-2023, 09:13 AM   #11
1994 25' Excella
The converter has nothing to do with the solar. There is a separate solar charge controller responsible for that.
Richard
11018
Old 09-26-2023, 09:41 AM   #12
2016 16' Sport
Miami , Florida
Thats why I questioned this post. There are lots of folks that are new to this. I would hate to see someone replace a good converter for the wrong reasons.
Batteries not charging via shore power??? crazylev Electrical - Systems, Generators, Batteries & Solar 32 09-07-2023 04:01 PM
Battery charging on solar NOT shore power rmroy Electrical - Systems, Generators, Batteries & Solar 36 11-02-2018 08:34 AM
Not charging from shore power wachuko Sprinter and B-van Forum 54 07-08-2018 06:04 PM
Shore power not charging battery after battery replacement P and Y Batteries, Univolts, Converters & Inverters 15 11-22-2016 09:36 AM
Batteries charging from solar but not shore power johndorst Batteries, Univolts, Converters & Inverters 3 11-16-2016 04:18 PM
