Old 08-17-2020, 07:32 AM   #41
2019 Basecamp
Whitefish , Montana
Bob-
It is not the BattleBorns per se that have this characteristic -- it's a characteristic of the LiFePO4 chemistry.
The best accessible source I have found for info on LiFePO4 batteries is by someone named Rob Beckers -- "How to Find Happiness With LiFePO4 (Lithium-Ion) Batteries" on solacity.com.
You will often find these batteries delivered at half charge. I goose mine up closer to full charge before going out for a boondocking trip if I think I may park in the shade but if I will be moving during the day or otherwise have confidence about charging I don't go above about 80-90%. And when parked I try to leave at around 50-70%.
Battleborn may have secret sauce in their BMS or in the battery chemistry to avoid this problem -- maybe they never go above 90% SOC for example -- but if so you'd think they would hawk this as a market discriminator. Moreover, it's not documented anywhere that I have seen and from what people have recounted on the web it seems that their customer service / technical support folks have given varying answers to the question of whether it's good for the batteries to sit being charged at 14.2 to 14.4 volts.
Basecamp19 is offline   Reply With Quote
Original 2015 55 AMP Converter (battery charger). Removed for complete solar and electrical upgrade. Works perfectly. Gulliver72 Airstream Classifieds 0 06-15-2019 10:22 AM
2018 International FB27 Battery Charger timb2828 Batteries, Univolts, Converters & Inverters 3 05-13-2019 12:09 AM
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 10:21 PM
Question about wiring new battery charger on the battery side of the latching relay. BTUs4You General Repair Forum 3 07-27-2012 12:36 PM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 09:39 AM
