Hi all - this is Mike. In the process of adding an inverter to my Basecamp 16, I came across evidence of a high current short on the battery positive junction point and I wondered if anyone else here has noticed something similar? I found it because I wanted to up-gauge the wire from the battery box to the bus bar which is part of the
12 volt DC panel.
This issue can be found on back side of the positive junction point located on the side of the battery box. Unfortunately, it is not visible, even if the batteries are removed. The only way to see this issue is to remove the junction point from the battery box, or the battery box itself.
It seems like the wire was shorting out on the bolt for the insulator until the metal melted on the bolt and terminal, breaking the connection. This likely occurred right after the original AGM batteries were first installed.
The worst thing here is that this is an un-fused portion of the wiring system, allowing extremely high current through the short.
