Old 06-23-2020, 08:10 PM   #1
"Pura Vida"
2018 Basecamp
North Conway , New Hampshire
fan vent cover won't open
Just getting ready to leave in morning on XC trip, and when tried to open fan vent and turn on while loading, it won't open. The black handle tightens to right but when try to turn left to open is spins. Tried tightening the screw, and took it out and screwed back in but doesn't seem to be working. Worked fine when closed it about 2 weeks ago.
Is this an easy fix or do we need to look for dealer on way out?
Bob Schrader is offline   Reply With Quote
Old 06-24-2020, 10:03 AM   #2
FaFaFooey's Avatar
2021 20' Basecamp
Franklin , Wisconsin
I have had ours apart several times. Just remove the entire frame from the ceiling to see what is going on behind the crank. There is no caulk or anything that you have to worry about. Once you pull that out you can get to the actually lift transmission. Not much to that but maybe you can see something out of the ordinary.
Eventually I just ended up retrofitting ours with the Fantastic power lift with rain sensor and thermostat. Well worth the money!
ID:	371079   Click image for larger version
FaFaFooey is offline   Reply With Quote
Repair - Fantastic Vent Won't Open Al and Missy Roof Vents, Skylights & Fans 1 07-17-2019 04:30 PM
Fantastic Fan Cover Stuck - Won't Open time2play Roof Vents, Skylights & Fans 3 04-20-2016 10:48 PM
Fan-Tastic vent fan cover C FORD Roof 11 12-09-2015 12:47 PM
Why does the fan / vent pop open during travel? Airslide Roof Vents, Skylights & Fans 18 04-28-2009 05:21 PM
