Old 12-03-2017, 10:23 AM   #1
camperguy58's Avatar
2022 23' International
Folsom , California
CPAP in a Basecamp
Where do you set your unit at night? How do you power it?
Pat
International 23 FBT
Solitude 372 WBR
camperguy58 is offline   Reply With Quote
Old 12-05-2017, 09:12 AM   #2
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
Not for a Basecamp, but we added a separate AGM battery subsystem with outlets on each side of the bed for 12v CPAP plugs. We charge with a Honda 1000 for our 22 ft and with a 2200w Ryobi for the 26 ft. Of course, with city power, we just plug them in.
The outlets are in one of the shots here; https://www.airforums.com/forums/f39...er-155180.html for the 26 ft.
We priced the individual battery packs from the manufacturer for the CPAP and, believe it or not, putting in the separate system was cheaper.
Good luck,
Roy and Marie
64airstream is offline   Reply With Quote
Old 12-05-2017, 11:38 PM   #3
Dallas , Texas
I had dealer install 12v outlet next to USB On rear street side bench, running 12v power cord from below bed up near door to rear corner of bed where cpap rests. Solar recharged battery during day.
slurpee is offline   Reply With Quote
Old 12-07-2017, 10:39 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
my CPAP uses AC power. The 12volt system will run a pure sine wave inverter (the only thing that will run my CPAP)..with heated tube and humidifier you need to check your system for the power use and get an appropriate sized inverter. It is simple to run an extension cord from the inverter to the CPAP.
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-08-2017, 05:13 AM   #5
Retired.
. , At Large
Most modern CPAP machines will operate on either 12v or 120v. I purchased a 12v cord for Marie's machine, it simply plugs into the machine where the round power inlet is.
Old 12-08-2017, 05:40 AM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
My old CPAP ran on 12 volts. My new one runs on 24 volts. I use an inverter. I do turn the hose heat off and the humidity down when in the trailer. (Not a Basecamp).
CPAP Machine Useage mcomeaux Boondocking 39 07-19-2019 11:43 PM
CPAP Machines Chief Jeff Electrical - Systems, Generators, Batteries & Solar 13 09-19-2016 05:06 PM
Cpap Wildwash Batteries, Univolts, Converters & Inverters 8 08-28-2015 03:56 PM
12V power for CPAP machine. TomS Electrical - Systems, Generators, Batteries & Solar 16 10-30-2014 06:51 AM
3.0 Amp CPAP machine running off a Marine battery Lothlorian Off Topic Forum 9 08-15-2010 10:02 AM
