The cheap white plastic drain water valve handle snapped off on my 4 year old trailer.
I bought a replacement but I'm not sure what's involved in replacing it - it doesn't come out by simply undoing the two holes.
Anyone replaced theirs? My fear is that I have to unbolt the whole tank from beneath. I can't tell whether these bolts support the tank or if they're just for a cover. (?)
Can you see a small panel under the drain valve? I’ve replaced mine w/o removing the pan just the small access panel then the hose clamp should be accessible etc.
Shoot, Gary, I wish. It looks like it's one big solid cover.
I can suck it up and spend a Saturday undoing all the bolts, but I'm not sure what I'll find. Does the cover support the weight of the water and tank, or is it just a cover?
