Old 04-27-2020, 12:23 PM   #1
2019 Basecamp
Boise , Idaho
Basecamp minimalist bike rack
During my COVID isolation, I decided to take a shot at building a minimalist bike rack for our Basecamp X. I think it will pretty stable, but will know for certain when we’re allowed to camp again!
This is designed for mountain bikes with through-axles.
Materials
1x4 wood – about 4 feet (I used a leftover cedar fence slat)
2x2 wood – about a foot (used cedar again)
½ inch PVC pipe – about a foot
4 u-brackets to fit ½ inch PVC
Various screws and brackets as shown
Step one was to cut the 1x4 to fit the rear deck edge just in front of the metal lip protector. This allows for the right side 90-degree bracket to be attached (using a small carriage bolt, washer and wing nut) to the right side bench frame (just inside the storage area)
Step two, cut the PVC pipe to comfortable slide between the forks.
Step three, layout. The 2x2s should be mounted just short of flush with the PVC (this allows the forks to move smoothly into position without hitting the wood). The 2x2s also must be mounted at such a place that will allow the through-axle to slide into the forks and through, without being blocked by either the bench sidewall (left side) or the other PVC section (right side).
Step four, predrill and countersink all screws to prevent scratching the trailer floor.
Step five, mount the 90-degree bracket and straight bracket on the 1x4. Predrill the right side bench frame for the bolt/wingnut.
Step six, with the rack in place, measure a 1x4 to slide into the air slot on the left side bench frame. Between this board and the 90-degree wingnut attachment, the rack should stay in place.
We plan to secure the rear wheels to the d-rings using a short "river strap" that will snug the tires to the floor. We then will pad the front wheels in place, or toss them on top of everything in the back of our SUV.
I’ll post an update once we use this for real, but I’m hopeful this will allow us to safely carry our two bikes to camp!
Name:	Basecamp Bike rack mounted.jpg
ID:	366682   Click image for larger version
Name:	Bike rack 1st axle.jpg
Name:	Bike rack 2nd axle.jpg
ID:	366684   Click image for larger version
Name:	Basecamp Bike rack corner.jpg
Name:	Basecamp bike rack w bikes.jpg
ID:	366686   Click image for larger version
Name:	Basecamp Bike rack loaded.jpg
tatercamper is offline   Reply With Quote
Old 04-27-2020, 02:36 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
That's exactly what I did when we had our 2007 20' FC. Worked great.
ID:	366693   Click image for larger version
2019 Ford Expedition Platinum
Old 04-28-2020, 09:46 AM   #3
2019 Basecamp
Boise , Idaho
Looks like your bikes are the old style axles with open forks. Same concept, just a different mount hardware. Very nice.
Old 04-30-2020, 12:57 PM   #4
2019 Basecamp
EDMONTON , Alberta
Nice work, I am intending to build a mount out of aluminum to steady the bikes with the tires on and then strap them down into place. Hate taking tires off haha.
Dasponto is offline   Reply With Quote
Old 04-30-2020, 03:32 PM   #5
Wayne&Sam's Avatar
Images: 21
Well, I did say it was in 2007.
Old 04-30-2020, 03:47 PM   #6
2019 Basecamp
EDMONTON , Alberta
haha, and to be fair you can still buy bikes with quick release axles. Only the more enduro style mountain bikes have switched to thru axles.
Old 05-12-2020, 09:08 AM   #7
2019 Basecamp
EDMONTON , Alberta
Taking a little inspiration from my roof rack and discussions with my fab guy, came up with a rough sketch.
Will be matte black and welded steel. The end supports of the wheels I think will be foldable for storage. Will have a plate along the bottom of the tire to avoid damaging the floor and the sticky rubber bottom to help hold it in place when strapped down.
Will update when he sends me his sketches. He does a lot of house and custom fab work that I've done photography of before check it out!
https://instagram.com/iron_elements_...d=bd3846tjddquAttachment 367749Attachment 367750Click image for larger version
Old 05-21-2020, 12:05 PM   #8
"Pura Vida"
2018 Basecamp
North Conway , New Hampshire
We just picked up our Basecamp yesterday and avid mtnbikers. Was thinking of cutting a 2x4 to fit snuggly between seats and adding two front fork mounts, so could take out. Haven't tried yet but was wondering if they would fit side by side facing same direction if front forks mounted in line (not off set). You've answered one question, would they fit. Next step is how to fit in 2 road bikes as well. Thinking wheels in trailer and frames in back of Grand Cherokee, or was wondering about suspending somehow between rear shelves since both very light weight carbon frames.
Bob Schrader is offline   Reply With Quote
Old 05-26-2020, 01:28 PM   #9
2019 Basecamp
EDMONTON , Alberta
Saw you posted on the facebook page as well. Definitely a lot of bikes to fit in there! As it was mentioned, avoid hanging them from the bars as they aren't that sturdy load wise.
Our two mountain bikes need 28" spacing to fit facing in the same direction and pedals extend about 5" beyond that on each side so we know our bikes will have to be put in opposite directions to fit (the benches are 32" apart).
Old 06-16-2020, 11:06 AM   #10
FaFaFooey's Avatar
2021 20' Basecamp
Franklin , Wisconsin
I took some inspiration from tatercamper and built a similar bike mount. The wife did not like the idea of drilling into the seats so I had to come up with some way of easily clamping it in. After a few different designs I came up with one that clamps in using simple push/pull toggle clamps. I tried different forms of rubber to put on the ends of the clamps and eventually ended up using rubber feet from my local hardware store. These seem to hold the best using minimum force. We have used it only once so far but it held strong over a 400 mi trip.
ID:	370514   Click image for larger version
ID:	370516   Click image for larger version
ID:	370518   Click image for larger version
FaFaFooey is offline   Reply With Quote
Old 07-09-2020, 11:10 AM   #11
2019 Basecamp
EDMONTON , Alberta
That's a wicked set up. Definitely well done!
Our mileage really didn't take a hit with them on the roof. So up there they will stay now. Click image for larger version
Basecamp Bike Rack MTB Basecamp Base Camp 8 06-04-2020 02:44 PM
Minimalist Tool Box John&Vicki General Repair Forum 20 10-23-2019 01:41 PM
Off Grid Electricity - A Minimalist Approach NWGetaways Electrical - Systems, Generators, Batteries & Solar 49 08-05-2019 04:29 PM
Minimalist vent fan upgrade for 68 Overlander fitzjo1 Roof Vents, Skylights & Fans 0 07-05-2015 01:33 PM
Minimalist restoration of Caravel hodol88 Interior Restoration Forum 6 09-02-2014 08:02 AM
