Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Base Camp
Old 11-02-2019, 12:51 PM   #121
2019 23' International
sarasota , Florida
Old Today, 12:44 PM #1
scottyb
sarasota , Florida
Gained awesome space inside Basescamp
Hi Basecamp owners!
My wife and I happened to see a great space gaining solution for our 2018 basecamp on YouTube.
We made a cut on the side foldout boards and hinges down to the size of the shorter back cushions. You need to have an 1/8” gap between the cut so the boards pass each other with ease.
This allows us to have the bed setup and keep a table top set up at the same time. It also allows us to get to some storage under the bed easier when the bed is set up. For sleeping we just drop in the shorter table post , cover it w the 2 shorter cut boards we now have and the 2 back cushions and pull the foam mattress topper we use down to cover it. That converts it back to a king size bed ! during the day just pull the foam topper back towards the back door to approx a full size bed and set the taller table in place. Then use the 2 smaller cushions as back cushions at the 2 seats that are created in either side of the table .
Pictures to be attached.
This was an awesome improvement!!! Gives us so much more room to move around when 2 people are in the trailer . Airstream execs take note ! This is a very easy and inexpensive modification that is guaranteed to be a hit with basecamp enthusiasts .
Scott and Gail! Email me with any questions .
scottyb is online now Report Post
scottyb is offline   Reply With Quote
Old 11-02-2019, 01:00 PM   #122
sarasota , Florida
Pictures for gained space.
ID:	355456   Click image for larger version
ID:	355458   Click image for larger version
Old 11-02-2019, 01:02 PM   #123
sarasota , Florida
Little mor.
Old 01-03-2020, 03:35 PM   #124
2019 Basecamp
EDMONTON , Alberta
Originally Posted by Tom P. View Post
Added runners to drawer - works just like home! Made a new drawer with thicker bottom to accept screws and dividers for my specific implements. Wanted this since day one. 22" guides juuust work. You can juuust reach to screw them down in the back, beyond the recess where the original tray sat.
Definitely need to do this. Great idea.
Dasponto is offline   Reply With Quote
Old 04-23-2020, 03:50 PM   #125
RG9999's Avatar
2020 16' Basecamp
Fort Worth , Texas
Originally Posted by RocIngersol View Post
Hello Basecamp fans,
Roc Ingersol here reporting on some new improvements.
1. Installed offroad tires as we do remote camping in desert southwest. See attached picture.
2. Removed Dometic refrigerator and replaced with Engel 12V/120V unit - please see Refrigerator performance thread for description and pictures.
Best Regards,
Roc Ingersol
Great looking all terrain tire upgrade to your Basecamp Roc.....can you tell me make/model/cost information?
RG9999 is offline   Reply With Quote
Old 04-24-2020, 08:32 AM   #126
2019 Basecamp
EDMONTON , Alberta
Originally Posted by Lmnhead View Post
Thanks so much for the zipper extender tip! We've already had to use needle-nosed pliers to grab one below the frame.
We also use S-hooks to hang various items from the overhead bins, and have a USB powered fan.
I might have been slow on this one - the storage area underneath the seating has been a pain to load/unload while trying to keep the top open. Finally I solved that with a bungee cord hooked to the overhead bin. I can organize with both hands free now! Attachment 290972
I would definitely look at doing a gas shock off on the side instead to avoid the above mentioned smack on the head.
Little gas shock from princess auto should work great in this application, few others have done it already as well. I will be doing it here over one of the next few weekends. I'll share photos once I am done
Old 06-08-2020, 12:30 PM   #127
2018 Basecamp
La Habra , California
Custom teak shower mat is great and is a perfect fit
Mrvad is offline   Reply With Quote
Old 06-08-2020, 12:34 PM   #128
2018 Basecamp
Did the same bed mod to my 2018 BC.
Old 06-14-2020, 04:05 PM   #129
2020 16' Basecamp
port chester , New York
the vent allows a lot of light to go through which sort of defeated the purpose of the blackout blinds.
i bought this and am extremely happy with it. You need to unscrew the frame and tape some magnets but it took 5 minutes. It makes the interior basically completely dark and does a great job of absorbing some heat.
I would recommend every basecamp owner to get it
https://www.vanmadegear.com/product/roofvent/
mango315 is offline   Reply With Quote
Old 06-22-2020, 04:47 PM   #130
Houston , Texas
Bed Hack in Kitchen
Hey AS Basecamp owners ..Has anyone added like a half wooden table to the countertop and added cushions for a kids/todler bed? A Flat suface that fits over the counter and hangs over a bit with two fold out support legs. Collapsible of course for when not in use.
Hack-a-way bed.
Not an owner yet but soon.
CybrPnkJdi is offline   Reply With Quote
Old 06-23-2020, 08:07 AM   #131
2019 Basecamp
EDMONTON , Alberta
Hack-a-way bed.
There was a guy on the facebook page that was looking at getting a fold out support piece that would go over the counter. I'll do some searching and see if he ever finished it.
Old 06-24-2020, 04:21 AM   #132
Houston , Texas
Old 06-24-2020, 09:45 AM   #133
2020 16' Basecamp
Atlanta , GA
TV Mount in Basecamp
I recently purchased a 2020 Basecamp X. I want to install a TV. Small, probably 22". I want to mount it on the exterior bathroom wall. What is the wall made of? Can it support a TV mount? What type of screw would you use?
Thank!
ChizzyHat is offline   Reply With Quote
Old 06-24-2020, 09:49 AM   #134
2020 16' Basecamp
Atlanta , GA
Yes. I did this. I will post pictures when I get the mattress. Probably today. It is three pieces or 12" malmine board cut to the shape of the kitchen area sitting on 1.25" pegs with rubber feet to sit above the stove/sink/etc. It has feet to hold it up in the void between counter tops. I am a grown man and it supports me great. It is 6' wide at the widest point too.
Old 06-24-2020, 09:51 AM   #135
2020 16' Basecamp
Atlanta , GA
Yes. I did this. I will post pictures when I get the mattress. Probably today. It is three pieces or 12" malmine board cut to the shape of the kitchen area sitting on 1.25" pegs with rubber feet to sit above the stove/sink/etc. It has feet to hold it up in the void between counter tops. I am a grown man and it supports me great. It is 6' wide at the widest point too. Also, it is hinged, so it fold up and stores under the bench
Old 06-24-2020, 09:52 AM   #136
2020 16' Basecamp
Atlanta , GA
<New of the forum, not sure if I am posting right>
Old 06-24-2020, 10:23 PM   #137
2018 Basecamp
I use command strips by 3m they work quite well. That way I can move it any rime anywhere. I even put it on the outside to watch football, last season. I don’t know if you’ve used command strips before but they have coat hooks and other gadgets that all work great in the basecamp.
Old 06-28-2020, 09:19 AM   #138
2020 16' Basecamp
Norman , Oklahoma
We purchased the Weber Q1200 "Airstream Edition" grill (from Airstream Supply Co.) that came with the proper hose to connect right into the outdoor LP port. I use a natural Gas Weber at home and cook out every week - I was really impressed with how well this little grill cooked. We also ended up ordering the 1/2 griddle grate replacement for it. It's great to be able to cook as much as you want outside.
D Shauberger is offline   Reply With Quote
Old 07-02-2020, 08:21 AM   #139
2019 Basecamp
EDMONTON , Alberta
We found the baskets in the Basecamp to be quite inadequate.... so time for custom!
IMG_20200625_155659_426 by Ryan Ponto, on Flickr
Local custom fabrication guy that I do photos for (Railings and Houses) is upgrading our baskets. All three will be 3/8th square bar, powder coated black. We will be changing out all the hooks in the galley to match, as well they are doing a custom towel bar to be 3m'd onto the glass next to the fridge.
More pictures to come!
Old 07-14-2020, 09:52 PM   #140
2020 16' Basecamp
Atlanta , GA
I installed two 18 LB gas struts and they work amazing
https://www.amazon.com/dp/B0156P6YVC...p_mob_ap_share
Axle hacks sdsmarts Axles 4 04-03-2015 10:20 PM
