Old 07-20-2020, 09:52 AM   #1
2006 Base Camp
bend , Oregon
Basecamp 16 tow vehicle
I have a unique opportunity to get a tow vehicle which will also be a daily driver. We have a 2007 basecamp. We live at 3500' in Central Oregon and figure we will be traveling out west on extended trips, long weekend to week long with the wife and kid.
Right now in the running are a Tacoma and a Tundra. I am just wondering if the Tacoma is over kill , or will the Tundra be underpowered on some of the hills and passes.
Appreciate any real world experience with towing the basecamp
erik is offline   Reply With Quote
Old 07-20-2020, 10:07 AM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Since the Tacoma is a mini truck, and a Tundra is a full size truck, I would say the Tundra is more oversuited. The Tundra will do worse on gas, but you can carry more stuff with you.
Old 07-25-2020, 10:07 PM   #3
2020 16' Basecamp
port chester , New York
I think it depend which package you have for the tacoma
we are about 2 weeks into a long road trip using an Audi Q5 as a tow vehicle (rated to 4400) and I am pleasantly surprised. We have done mountain passes at about 10,000 feet and felt 0 issues or wishes for having a stronger car.
mango315 is offline   Reply With Quote
Old 07-26-2020, 06:06 PM   #4
2019 Basecamp
EDMONTON , Alberta
We love our Q5 as well! About 5k km in so far and about to do 2k road trip through the rockies next Friday!
Dasponto is offline   Reply With Quote
Old 07-26-2020, 06:30 PM   #5
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
erik, as overlander63 said the Tundra would be better equipped with more payload and towing capacity (V8 vs. V6).
Do you think your Basecamp will be your last Airstream? We're on our 2nd Airstream which required us to swap out the tow vehicle.
A Tacoma should do the job for towing a Basecamp if properly equipped. A Tundra might not be as good of a daily driver but would be good for towing a 23' Airstream easily. Many on the forum tow 25' or larger as well but at that point a 3/4 ton is more popular. Check the door sticker of any truck and look at the payload. More is better! A 25-27' AS needs at least 1,500 minimum payload to comfortably tow. Our RAM 2500 has 2,940 lbs. payload.
Good luck with your selection.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 07-26-2020, 08:19 PM   #6
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
I would look for the best mileage and go from there. The Basecamp is quite light and towable. Just assume about 500 lbs tongue weight so the truck needs to be able to support that and have some head room if you add more stuff to the trailer down the road.
Your cargo capacity will be a major consideration as Jeff stated. For example if Toyota says you can tow 6000 lbs and have tongue weight of 700 lbs. And your cargo capacity is 1,500 lbs. Once you deduct 500 lbs for the trailer tongue and say 300 lbs for 2 people, you are left with 700 lbs of cargo that you can carry. Add more people and stuff and you will be at or over your max cargo very quickly. It doesn't matter that you still have 2,500 lbs left in towing capacity.
So start by comparing Tow Maximums, Tongue Weights and Cargo Capacity. Give your self a buffer as the published numbers are usually very optimistic and add to confusion when faced with the reality in front of you.
Good Luck with the choice.
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is offline   Reply With Quote
Old 08-01-2020, 10:13 AM   #7
2006 Base Camp
bend , Oregon
Thanks everyone we have decided to go with the Tundra since we may upgrade in the future!
Basecamp tow vehicle question seshields Base Camp 19 11-04-2019 10:41 PM
Basecamp Tow vehicle - RAV4 Adventurer? Fredjacob Base Camp 14 10-13-2019 11:07 AM
Basecamp tow vehicle question seshields Tow Vehicles 10 01-09-2019 11:37 AM
Tow Vehicle/STOW Vehicle for Full-Timers Foiled Again Full-Timing 13 06-28-2014 12:55 PM
