Old 08-13-2023, 08:13 PM   #1
2023 16' Basecamp
Creighton , Nebraska
Base Camp Rear Door Latch Improvement
The rear door on our 2023 BC16X was difficult to latch on top, even on the delivery walk-around we were told that it needed to be slammed to insure that it would latch. The only way we could tell if it latched on top for sure was to push on it from the inside. The problem I found was burrs on both the locking bolt and the strike plate. I used a fine gunsmithing stone to remove the burrs and put a very slight radius on the tip of the bolt and on the edge of the strike plate. Make sure that you don't change the profile of anything except the small radius. Now to latch the door, close it gently so nothing latches. Then push on the top first and you will hear the top bolt latch and then the same on the bottom. The latch on the side door had the same problem.
pfm41 is offline   Reply With Quote
Old 08-13-2023, 08:45 PM   #2
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Also helps a lot to put lithium grease on the locking surfaces- don’t have to slam mine
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 08-15-2023, 07:49 AM   #3
2023 16' Basecamp
The lube didn't help much before I smoothed it up because the burrs would prevent the bolt from reliably latching. Yes, the lube is a must.
Base Camp 16X Side Door deadbolt pfm41 Base Camp 1 06-10-2023 12:03 PM
Northern base / Southern Base capt george Full-Timing, Winter Living & Workamping 16 04-04-2019 08:17 PM
'79 rear bumper lid and compartment improvement? blickcd Bumpers & Bumper Storage 9 08-03-2017 08:08 PM
Screen door latch improvement? RivaHaven Windows, Doors, Locks & Vents 11 01-15-2017 11:48 AM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
