Old 07-30-2019, 11:22 AM   #1
2018 Basecamp
Great Falls , Montana
Back door outer skin
Has anyone else had the aluminum pull away at the back window and license plate holder? Ours recently separated approximately 1/4 to 1/2 inch on both sides of the back window and the left side of the license plate holder. We’re headed out on a 5000 mile trip and felt we needed a quick fix since a trip to our dealer (200 miles away) was not possible before we are scheduled to leave. We used Sikaflex 221 to bond and seal the aluminum to the door. When we return, I think we will be asking for a new rear door. Any thoughts or suggestions?
Dsprout is offline   Reply With Quote
Old 08-04-2019, 03:32 PM   #2
remote , AL
Any dealer should be able to fix it on your 5000 mile trip , I go out of my way to avoid the original dealer I purchased from.
I would look for a 5 star rivet dealer , they are normally happy to fix warranty issues
navathehutt is offline   Reply With Quote
Old 10-30-2019, 09:04 PM   #3
2017 Basecamp
Highland Village , Texas
Do you have any pictures of where your is separated? I have a small separation at the bottom of the rear widow and a small crack in the plastic sill area inside where it's separating. It also leaks water in the same area.
JJ
Saltflyer is offline   Reply With Quote
Venting refrigerator in space between outer and inner skin Jeremy9107 Refrigerators 6 02-23-2018 11:37 PM
'16 Flying Cloud 25a heat pump condensate running down outer skin majorairhead Furnaces, Heaters, Fireplaces & Air Conditioning 2 05-08-2017 06:38 PM
Outer skin of unit (roof to outer wall) jaharper Ribs, Skins & Rivets 1 08-01-2011 01:05 PM
Outer Skin Leak 63 Safari srgntpepper Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-23-2003 02:20 AM
Leaky Outer Skin 63 Safari srgntpepper Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 09-10-2003 06:43 PM
