Old 04-10-2021, 06:47 AM   #1
2018 27' Globetrotter
Mooresville , North Carolina
Air Conditioner Issue - Recall
I donít have a Basecamp but have read some posts about the air conditioner coming off the roof while in transit. My latest Harvest Host newsletter noted that Airstream has issued a recall notice to fix this issue.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
GOUSC is offline   Reply With Quote
Old 04-10-2021, 06:56 AM   #2
See attached photo
"Roadrunner"
Old 04-10-2021, 08:12 AM   #3
Long Island , New York
FYI --
https://static.nhtsa.gov/odi/rcl/202...1V195-9638.PDF
https://www.nhtsa.gov/vehicle/2020/A...SECAMP#recalls
Other AF mentions of this issue:
https://www.google.com/search?q=base...=airforums.com
FYI
FWIW
Peter
Let the music lift you up . . .
Old 04-10-2021, 10:14 AM   #4
2019 Basecamp
Whitefish , Montana
I'd want more than the fix in the recall
Now that Airstream has admitted there is a serious safety issue it's necessary to address whether the fix is sufficient. Does Airstream have tests or is it just following the available direction in the Air Conditioner installation guide? And does the fix include the more robust mounting kit recommended by the manufacturer or just the additional spring pads?
My fix involved stronger bolts, stiffening washers, steel spacers, and locknuts on top.
It does not appear that the recall fix includes stronger bolts. The additional "foam support blocks" mentioned in the recall are presumably the "spring pads" recommended by the air conditioner manufacturer to maintain tension on the bolts. I do not believe this is adequate to guarantee the bolts don't loosen, especially in colder climates where the pads may stiffen. The manufacturer also recommends double stick tape and mentions the possibility of adhesive caulk to help keep the a/c in position on the roof. These are all band-aids. The mounting should be strong enough so the bolts don't shear even when loosened and even when the AC is sliding on the roof.
The Airstream fix may be "engineered" by lawyers to eliminate liability rather than by actual engineers to ensure the AC stays on the roof in the Basecamp. Remember compared to most RVs the Basecamp (especially the X) is advertised for more off-road use and the AC is more prone to falling off owing not just to the accelerations from off-road use but also the slanted mounting position.
In my view the mechanical attachment should be strong enough independent of friction on the roof. Hence the stronger bolts, stiff spacers, stiffening washers and locknuts in my fix. I of course have no test info showing my fix is adequate but it's a lot better than what Airstream is going to do.
Disclaimer: I am neither an engineer nor a lawyer.
Basecamp19 is offline   Reply With Quote
air conditioner issue - fan on auto?? Gmutt Electrical - Systems, Generators, Batteries & Solar 2 08-25-2016 07:17 PM
URGENT SAFETY ISSUE - Sturgis Regulator Recall khollister LP Gas, Piping, Tanks & Regulators 41 07-09-2016 05:59 AM
air bag recall xrvr Sprinter and B-van Forum 6 02-17-2016 07:55 AM
Strange Air Conditioner issue Landrum Furnaces, Heaters, Fireplaces & Air Conditioning 15 06-28-2015 10:53 PM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
