2nd Basecamp bed
Hi,
I'll attach photos (I'll try....it's not real obvious to me if the attachments were uploaded correctly....). There are 6 individual pieces, going around the contour of the sink, cooking area, using 3/4" plywood. The 6 pieces are cut to be able to be stored under the bench. In the photos you'll see I have left the "long" piece bolted together, but when on the road it would be separated and stored with the other 4 pieces. It is made more for a child, but I'm 170 and it holds me no problem, as it does my 200 lb son.
What's needed to finish: 1). 1/4" to 3/8" rubber "feet" under the plywood pieces, to raise the plywood above the sink, cooking area, and collapsed plug tower. 2) A piece of wood on the near edge, so sleeper doesn't roll off onto the floor. 3). A foam mattress, like everyone purchases for the Basecamp bed.
Hope it helps.
Tom
