04-10-2003, 07:06 PM
Aluminut
2004 25' Safari
Tire pressures
Ok, I was out at a party and got into a conversation about tire pressure. One person said that you fill the tire to the suggested pressure when the tire is cold.
Another said that if you fill it to the suggested pressure, as the tire heats (due to the rolling resistance), it will exceed the max pressure and is more likely to blow out.
I am currently in the camp where I do not fill the tires all the way. For example, the car states 44psi. I tend to fill to 38-40psi so as the tires heat up, the do get to 44+psi. In winter, as it is cold out here, I fill the tires to 44 and as it gets colder out, I need to add about 8-10lbs. When spring arrives, I have to take some out since as it gets warmer, the tire pressure increases and I need to compensate.
On the trailer, I believe it says 2540lbs at 65psi cold. These are the standard "D" rated Goodyear Marathons.
So now I am torn. Do I fill the tires to the 65psi on the camper and 44psi on the car (cold) when on the road with the rig and allow them to heat and possibly exceed the 65 and 44psi or will it not exceed the pressure as it gets hot. I can't see how it can't with physics being what it is......
Regards,
Eric
04-10-2003, 07:17 PM
I'm not a tire expert but, I think you are right. The figure is the Max inflation rate, not THE inflation rate.
04-10-2003, 08:23 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Tire pressures
Greetings Eric!
The inflation pressure listed on the sidewall of the tire is the designed maximum pressure that will permit the weight carrying ability molded in the sidewall. The weight carrying ability of the tire decreases as the inflation pressure goes down. I would suspect that with your new Bambi you would have recommended inflation pressures in your owner's manual. No such information is provided in my '64 Overlander owner's manual, but then it was Airstream's first attempt at producing an owner's manual. Since the manual doesn't contain the information and my Good Year dealer was vague about what reduced inflation pressures would do to the weight carrying ability; I have always run my Marathons inflated to the maximum listed on the sidewall. I carry a small, portable air compressor that can be run from my inverter so that I can fill the tires before the trailer is even on the road at the beginning of the day - - I also purchased a high quality tire guage at a local truck supply so that I am reasonably confident in its readings. It has been my experience that when inflated to the maximum indicated pressure that the tire runs cooler and lasts longer.
(I have run the Michelin tires on my Suburban at the maximum rated pressure since they were installed at 45,000 miles - - the truck now has nearly 104,000 miles and the tires still have about 15% treadwear remaining - - the dealer estimates another 10,000 miles before replacement.)
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
04-10-2003, 08:44 PM
Moderator Emeritus
1972 31' Sovereign
High Springs
It says 65 PSI COLD, then fill it to 65 PSI and don't worry about it. Like Kevin says, the tire will run cooler and last longer with more pressure in the tire.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
04-11-2003, 07:55 AM
2003 25' Safari
Kissimmee
I agree - tire pressures should be checked and set when COLD - see Tire Rack
Dan
04-11-2003, 11:11 AM
The Real Answer to Tire Pressure
I worked for Michelin Tire Corporation for 7 years and Yokohama Tire Corporation for 11 years. I have given numerous tire seminars on tire maintenance and especially how to determine the correct tire pressures. So here goes.
The pressure on the sidewall of the tire is the maximum pressure at the published load at approximately 55 mph. (The speed can vary somewhat but it is not important for our discussion).
The air pressure is required to support the load that the tire must carry in such a manner that the tire flexes at the designed place on the sidewall of the tire.
If the load on the tire changes then the air pressure should change accordingly to keep the tire flexing at the proper place.
The reason for correct air pressure is to prevent the tire from overheating. It was put together with heat and it will come apart the same way. An under inflated tire will eventually self destruct due to excessive heat build up. An over inflated tire will ride harshly and be more likely to burst upon impact. Sorry for the long explanation but here is the bottom line.
To determine the correct air pressure, check the pressure when the tire is cold. Run the tire for several miles at highway speed. Stop and immediately check the air pressue in the tire. It should be higher than we cold but no more than 10% higher.
Now here is the hard to believe part. If the pressure is more than 10% higher you must ADD AIR and test again. For example if you start with 50 psi cold. If the pressure is 60 when hot, you have exceeded the (10%) in this case, 55 psi maximum safe heat build up pressure. You must ADD AIR. In this case I would add 5 psi which would take the tire to 65 psi when hot. After you run the tire again you will find the pressure to actually drop because the tire will run cooler. The heat build up causes the tire pressure to increase when under inflated.
On the other hand, if the 50 psi cold pressure does not change when hot. You have more air than needed. You can remove 5 psi or so and test again when they return to cold. Like the next trip you take.
So a fully loaded rig will require more air in the tires than one with empty tanks and a light load on board. Always error on the side of over inflation. Thus the maximum sidewall pressure indicated on the tire is usually used. It usually is more than needed. Each axle has its own requirement based upon the load on that axle.
So how do I get a 2 Rivet rating? Does this long explanation help or hurt?
04-11-2003, 11:25 AM
Always err on the side of over inflation.
Great post, thank you.
Mike always makes sure that our tires are inflated to the recommended max. The problem we often encounter when having a tire mounted, is a lot of shops refuse to inflate that tire according to manufac. specs. !!!
We have to insist, or add air ourselves afterwards. A lot of people ride with under-inflated tires because they like a soft ride. As you said, they don't understand that not only their tires will over heat, but they will get lower gas milage.
04-11-2003, 12:06 PM
Aluminut
2004 25' Safari
AM,
Thanks for the detailed post. All tires will have the correct inflation now.
Thanks a bunch!
Eric
04-12-2003, 09:08 PM
2004 25' Safari
Interesting posts on a subject I knew little about. Great info as I read thru the list last night. got to thinking that I now need to buy a digital pressure gauge, etc. & start paying more attention to the tire pressures. Today in the mail what appears, but a mini air compresser & a digitial tire gauge, a belated birthday gift from my daughter in Virginia. Now I need to go back over the posts & see what I missed. Appreciate all those who gave freely of their advice, on the importance of the proper tire pressures.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
04-12-2003, 10:57 PM
1959 22' Caravanner
Atlanta
, Georgia
Great information AM. Thanks.
I have heard so many things and some of it even printed. One method was to fill tire to max pressure and roll it (with the weight of the vehicle of course) accross a peice of paper or some calk powder and look at the pattern. If the pattern shows lack of full contact on the sides to let some air out. This was printed in a popular 4x4 mag.
I run BFG 32x11.5 MT's and 31x10.5 A/T's on my 4x4's. The tires I was running were rated 50psi max but the added gross total of the weight capacity was well in excess of the vehicles listed GVWR. The second issu was the max PSI rating of the stock Chevy rim they were on was 40PSI.
I ran those tires at 36PSI and I have tested the pressure after running them. I have never found the tire to gain no more then 3PSI due to heating so I guess I was pretty close. 2more PSI and I would proably have been right on. The tires have been wearing even and extreamly well. I put 20k on one set of MT's and they still had another 15-20k left to go and actully sold them to somebody else who is still happy with them.
I guess I'll play with the Load range E Michelins on the new burb. Previous owner has been running them at 55psi and they are firm but not adversly except on choppy pavement. I havent even read the sidewalls yet so not sure the max rating but I think it's near 65psi. The door sticker recomends 44 front and 60 rear with 4 passengers. But that was the original tires and may not be the same requirments as these tires.
Since you have some knowledge here what is the max width rim I could run these 235/85/16's on safely? They are on a set of stock GM steel rims 6.5 inches wide and I would like to dress the truck up some (hate thos huge pizza pan hub caps). I know somebody with a very nice set of Aluminum rims for sale but they are 16x8 and I was concerned that would be a little wide for these tires.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
04-13-2003, 12:10 AM
1978 31' Sovereign
Escondido
Inflation pressure
As mentioned the load rating of the tire changes with inflation pressure - more pressure more load capacity. Manufactures can provide the load rating at different pressures for tires so you can be sure you are not running the tires undreinflated. They are most likely to have the info available to the public for tires that are used over a wide range of loads such as in trucks and motorhomes etc. I was able to get a load rating for the Michelens I use on my truck from the lowest recommended pressure to the highest by making a few phone calls.
The procedure of adjusting the pressure until the pressure rise is in the correct range would seem to be pretty good advise.
Would the amount of moisture in the air (air used to inflate the tire) change the pressure you should run? I know it will change the amount of pressure rise. Thats why racers fill tires with Nitrogen.
APB
Bluegrass is flat picking good!
04-13-2003, 09:38 AM
For a discussion I will call interesting , check this: Nitrogen in the tires
04-13-2003, 08:51 PM
In replay to 59toaster question regarding rim width acceptable for your tires: Each tire manufacturer has a published acceptable rim width size for their tires by size. It is sometimes difficult to find a tire dealer that will show you in writing the correct answer. The manufacturers have the information readily available if you contact them directly. I have been out of the tire business too long to make a specific recommendation in this regard. Just contact a knowlegeable tire dealer or the manufacturer. Thanks for the good words. Good luck.
04-13-2003, 09:00 PM
The problem that moisture causes in a tire is that it promotes rust on the rim. It should have no effect regarding the correct air pressure. The correct air pressure caues the tire to flex in the correct area of the tire sidewall. The tire is a rolling spring that needs to flex in the proper range for best results.
04-15-2003, 07:58 AM
1959 22' Caravanner
Atlanta
, Georgia
I have been playing with my tire pressure using the method AccessMaster Outlined.
Very neat. It really works.
Last night I checked the pressure before heading home. Ambient temp was about 70deg. Ira, The PO of the Burb, Had told me he was running 55psi in these Michelin tires. This was right in line with the recomendations by GM on the door frame. Problem is these are not the same tires that the truck came off the line with so they probably have different ratings for PSI. The Max cold air pressure on the side wall is 80PSI.
I checked the pressure and according to my gage they were a 56 at the current air temp. Drove the truck 19 miles down the freeway at 65mph. Checked the air pressure and it was reading 64 after heating. SO I went over the 10%. This morning it was 57deg. I checked the tire pressure. Showed just shy of 56 on my gage. I added air till they showed 60psi. Ran 19 miles up the road to work and checked them again. 64psi after heating. Try it again on my way home when it should be about 72 degrees outside. Tomorrow I'll add 2 PSI and see what happens.
Neat trick and did learned something from this. Thanks for passing this on. What I really like is even if the gage is a couple degrees off it doesn't matter. You just need the pressure change after heating.
I'm going to pass this on to another Forum I'm on.
1959 22' Caravanner
Atlanta, GA
04-15-2003, 05:54 PM
1986 25' Sovereign
Southern Middle
, Tennessee
Last year while visiting with my sister of 50 yrs., we got into a discussion concerning tire pressure in her Nissan Frontier crew cab truck. I found that she had always filled tires on her Thunderbird, her Nissan Maxima and this Frontier to the pressure stated on the tire rather than on the door sill. And she wondered why all these vehicles always rode stiff. I explained that the tires should not be filled more than this max. rating and since she does not load her truck down, the pressures on the door should be used as guidelines.
My '01 Chevy 2500hd has E rated tires with max. inflation of 80 psi. The door sticker states 55 psi for front tires and 80 psi for rear. Can you imagine how rough that thing would ride if I ran 80 psi front and rear? I run 55 front and rear when not towing and then increase to 70 in the rear when towing. It is my understanding that the 80 psi in the rear would be if you have the max towing weight and tongue weight. It would seem to me that you would lower the rear tire pressure to coincide with the reduction, if any, of towing/tongue weight.
Lastly, my owners or service manual (can't remember which right now) talks about increasing tire psi on the trailer as your weight goes up. I run around 55 psi and this is not the max because I do not load my trailer heavily. I can't see where running the max psi for a trailer not loaded to the max would help rivets stay in place. On the other side, underinflation is not a good thing for trailer tires in my opinion. I would rather slightly overinflate rather than underinflate.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
08-20-2004, 12:02 PM
1967 26' Overlander
Huntsville
, Alabama
Min not Max Pressure?
In trying to confirm everything I've been reading about correct tire pressure, I ran across something about Light Truck (LT) tires I had never seen before:
From http://www.rvknowhow.com/toyotire.html
It is important to note that the inflation pressure molded on the side wall of a passenger-car tire is the maximum air pressure for that tire. That is not the case, however for light-truck tires.
The inflation pressure molded into the sidewall of light-truck tire is the minimum (that's right, the minimum) air pressure required for that tire to carry the maximum weight molded into the sidewall of that tire. Using less air pressure means the light-truck tire must carry a lighter load.
While the tire-load rating molded into the sidewall of a light-truck tire should not be exceeded, it is generally recommended that the tire be inflated to the minimum pressure required to carry the load plus an additional 5 - 10 psi. The extra pressure will help the tire run cooler. It also acts as a reserve to offset normal loss of air pressure. But the extra pressure will not add to the tire's load carrying capability. Just keep in mind that the maximum air pressure for a light-truck tire is the minimum air pressure molded into the side of the tire plus 10 psi.
My Load Range C LT tires are stamped 45 psi. After reading the above, I guess I should be running a minimum of 50 psi?
Tom
08-20-2004, 01:41 PM
2004 30' Classic Slideout
Fenton
, Missouri
Tom
What the author of that article is espousing is that it is better to overinflate since most tires will slowly lose pressure over time. While 5 lbs. is minimal you do have to be cognative that an overinflated tire is subject to an increased chance of road hazzard damage.
My process is to check my tires before towing and making sure they are at max inflation, rather than assume that the extra 5 lbs. of air has addressed any shortfall. In my experience on most trips, tire pressure is the same on return, as it was upon original departure. The only variance I have seen is when I changed altitudes or if there was a significant temperature difference between my two endpoints. In those cases I make the adjustment necessary to get the tires to cold inflation pressures before departing.
Personally adding 5 lbs. extra is just a crutch to avoid monitoring your tires for proper pressure.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
08-24-2004, 02:46 PM
Airstream recommends 55 lbs cold and a 65# valve, per a response I received from their on-line support last spring.
08-24-2004, 02:53 PM
1967 26' Overlander
Huntsville
, Alabama
That recommendation would be based on a specific trailer. Tires with different load ranges are inflated to different pressures.
I would not inflate my LR C tires to that pressure since the tire indicates 45 psi (although I have yet to convince myself if this is "max"). What is the load range on your tires?
Tom
