Old 11-21-2020, 04:35 PM   #1
2020 20' Bambi
Clayton , North Carolina
Touch Up Paint A-Frame 2020 Bambi
While I have used touch up paint on my truck and painted interior walls in house and touch up exterior I have not done so on trailer frame and want to make sure I don’t screw up. I have a few rust spots on A-frame where propane bottle cover has rubbed and around welded loops where safety chains connect. Do I just remove rust with wire brush, use some type of primer and then use a special exterior metal paint? If so on primer and paint, any recommendations? Thanks. Stephen
smsasf is offline   Reply With Quote
Old 11-21-2020, 04:50 PM   #2
1966 22' Safari
Fredericksburg , Texas
Google a POR-15 kit with the metal prep, primer and top coat. You can knock off what rust you can then apply the metal prep which encapsulates. It’s good stuff. Good luck
Bubba L is online now   Reply With Quote
Old 11-21-2020, 04:57 PM   #3
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
I would just use some gloss black Tremclad. If you wire brush the area first that would be good or at least scrap off any big bits of rust. You can try a rust inhibiter on the rust first before coating it. Clean it with some ISO alcohol to get all the oils off before painting.
I just hit mine with some glass black exterior spray while I had a can out touching up some aluminum.
It is probably going to come back so I would plan on re-coating it later on (maybe in the Spring). Mine has been good for 6 months but we are heading into our rainy season so time will tell.
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is online now   Reply With Quote
Got paint codes, looking for supplier of touch up paint DreamRoper Exterior Restoration Forum 7 07-02-2018 08:26 AM
Motorhome Touch-up Paint Gened Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 4 04-09-2007 05:31 PM
Argosy white touch-up paint? Dave and Pat Clearcoat, Exterior Paint & Trim 8 05-26-2006 05:33 AM
