I recently purchased a
1967 Sovereign Land Yacht and am planning to fix it all up and do a full monty. I'm sure I will need lots of help along the way. As of right now, I've got most of the inside gutted and I am curious about the sewage draining system because I am planning to put in a compost toilet. But, I'm probably jumping the gun. The plan as of right now is to cut the subfloor with a skill saw to see what the underneath looks like and to be able to remove tanks hoses, and or wires without taking off the belly pan. I will rest some plywood on top when that is done and then tackle taking off the skins. Once the skins are off and I've stripped the electrical wiring, I plan on taking it to get any outside panels removed and fixed. Once the outside is looking good, i'll pull the full monty - get the frame out, sandblast the puppy, rustoleum it, and install a new belly pan. Next, i'm thinking to epoxy the new subfloor and put the trailer back together. That's about as far as I have gotten in the planning process. Any help or if you think there is a better way to go about this, would be much appreciated.
