Old 03-15-2023, 06:16 AM   #1
2022 25' International
Charlotte , North Carolina
Stainless Steel Upgrades
I'm considering the stainless steel upgrade bundle for my trailer and just wondering if anyone else has done this. The bundle includes replacements for the range vent, outlet cover, fresh water port, cable/sat cover, and outside shower.
As with most things Airstream, the upgrades are pricey. My trailer is only a year old, so the replacements certainly are not a necessity, but only aesthetic. If you made any or all of these stainless steel upgrades to your trailer, was it worth it?
M3771 is offline   Reply With Quote
Old 03-15-2023, 07:27 AM   #2
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I took the various covers off and spray painted them silver.
kscherzi is offline   Reply With Quote
Old 03-15-2023, 08:06 AM   #3
Jeff7176's Avatar
2018 25' International
Full-time , Traveler
We dis all the stainless shortly after purchasing our trailer. I like them very much and would do it again.
Jeff7176 is offline   Reply With Quote
Old 03-15-2023, 08:07 AM   #4
Mollysdad's Avatar
I replaced my water heater cover and love it. I'd like to do the range vent and the outside shower, but I feel those are overpriced. ($95 for an electrical outlet cover?)
I shudder to think how much a "bundle" costs.
Mollysdad is online now   Reply With Quote
Old 03-15-2023, 08:38 AM   #5
"Cloudsplitter"
We did it when we bought "Cloudsplitter"...they cost 1/3 what they cost now.
"You don't know where you've been until you leave, enjoy life" RLC
Old 03-15-2023, 08:47 AM   #6
Josephine517's Avatar
2017 23' Flying Cloud
Beavercreek , Ohio
We swapped to stainless steel over several months in 2020. As COVID cancelled a reservation I used the money I would of spent on camping sites to purchase stainless steel. Ended up replacing most of the plastic parts. This year I changed out the cable and shore power ports to stainless RV Smart plug. I think the only thing I can change out at this point is the storage compartment lock. Hmm.
Josephine517 is offline   Reply With Quote
Old 03-15-2023, 11:12 AM   #7
"Cloudsplitter"
Found my original post about the stainless covers...
Old 03-15-2023, 11:23 AM   #8
2002 19' Bambi
Lafayette , California
After multiple silver spray painting episodes, I covered our water heater door and replaced our external stove vent with aluminum. If I hadn't wanted to have the challenge of making the aluminum covers, I would have purchased the stainless ones. The silver paint just did not last perhaps because of trying it for over 20 years .
Tim
Tim A. is offline   Reply With Quote
Old 03-15-2023, 11:44 AM   #9
mikeinca's Avatar
2020 25' Globetrotter
Santa Rosa , California
I replaced the outlet cover with stainless since I felt the plastic one was cheap looking and was also fading from sun exposure. It was a simple swap. I've also replaced the black luggage compartment locks with chrome ones that look better and have less common keys.
"Worth it" is obviously subjective but it's kind of fun to do the little upgrades and I'm happy with them.
Mike
2020 25' Globetrotter Twin | 2017 F250 4x4 6.7 max tow Platinum
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
mikeinca is offline   Reply With Quote
Old 03-16-2023, 06:22 AM   #10
Beavercreek , Ohio
The outside shower may require you to cut the rounded corners in the airstream siding to square. Mine 2017 23DFC required it, easy task with a Dremel tool.
Old 03-16-2023, 06:36 AM   #11
2019 25' International
Providence , Senior Electrical Engineer
We did it, but we had, still have, and issue with the hood vent. On my particular unit replacement, the seams where not beaded and it causes a leak over the stove when heavy sideways rain occurs. It is an action item to remove the vent, replace the gasket, and completely fuse/seal the areas that are causing the leak. I used a borescope to verify and could see the water coming it...lucky I was able to seal it off for the winter months...so just be aware that the replacement is nice, but can introduce an issue you didn't have.
kittmaster is offline   Reply With Quote
Old 03-16-2023, 12:10 PM   #12
"Cloudsplitter"
I used a length of split 1/8in clear tubing. (Granted black would have been better.)
That and my emergency MacGyver stay closed while moving clip, it's also a stay open clip so the fan don't have to blow the heavy door open and waste all that fan power.
Old 03-26-2023, 10:47 AM   #13
2013 31' Classic
Redmond , Washington
The flap that comes with the stainless steel hood vent is too heavy, it doesn't open with the airflow of the hood fan. I use a pinecone to keep it open permanently while camping. Not the best solution.
I didn't keep the old hood vent. Maybe there would have been a way to transplant the flap...
PacificNW is offline   Reply With Quote
Old 03-26-2023, 11:18 AM   #14
TeddyK's Avatar
Boston , Ma
There is ��
2005 25’ Safari Special Edition (International Package)
Sendel 16’s, Michelin Cross Climate, Shell on interior update (floor frame solid) Ampere Time lith batts, Victron Controls, Champion Dual Fuel 3400
WD Eaz-Lift 2 -1200lb bars 2-anti sway brakes
TeddyK is offline   Reply With Quote
Old 03-26-2023, 11:20 AM   #15
reginac's Avatar
Newport Beach , California
I replaced everything with stainless steel. It looks so much better! Also the kitchen vent cover will stick if not cleaned frequently. I use Dawn power wash to cut through the grease and then just wipe it off. It works perfectly when cleaned often.
reginac is offline   Reply With Quote
Old 03-26-2023, 11:34 AM   #16
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
We have replaced everything with SS except for the Fresh Water Tank Refill and the Outside Shower. The Airstream Service Center tech who did the work advised against those two items as you could run into trouble with short hoses and/or water leaks.
Randy
Randy & Pat Godfrey
Florida Airstream Club (027)
ACI# 1212 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
The best part of any trip is when you pull away from home.
SilverCabin is offline   Reply With Quote
Old 03-26-2023, 03:30 PM   #17
2008 19' Bambi
2018 23' Flying Cloud
Arroyo Grande , California
Stainless
We replaced all the outside covers on our 2018 Flying Cloud 23 FBQ with stainless. It wasn’t necessary, but we like the bling factor. The black lock on the storage locker was replaced with a chrome one.
Airsurfer is offline   Reply With Quote
Old 05-17-2023, 07:00 AM   #18
steilkurve's Avatar
2020 22' Bambi
2022 25' Globetrotter
St-Laurent , Quebec
Hey Bob.
I'm about to swap out my vent hood for the stainless steel one because the flimsy clips on the stock unit broke. And the stainless looks better of course.
Did you have to apply any sealant to keep the water out?
The AS Supply Co product page suggests it may be required, although they say a rubber seal is provided.
Any tips you have on that would be greatly appreciated.
Nic
steilkurve is offline   Reply With Quote
Old 05-17-2023, 07:11 AM   #19
Saluda372's Avatar
2021 20' Caravel
Plaistow , New Hampshire
Love the SS but hard to justify cost (as with most AS options). They could have done better with the original equipment, sometimes I feel they are building in additional profit by skimping on quality from the start.
Learning and enjoying as we go !
Saluda372 is offline   Reply With Quote
Old 05-17-2023, 09:47 AM   #20
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Originally Posted by steilkurve View Post
Hey Bob.
Nic
If I recall I used butyl tape when mounting and sealed around the edge with Sikaflex and blue painters tape to keep a tidy caulk joint. You may also need the clothes pin to hold the flap door open. The fan in the vent hood is not strong enough to keep it open.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Stainless Steel upgrades..Airstream.com or Silver Trailer Supply? RxGuy General Repair Forum 6 09-02-2019 02:25 PM
Stainless upgrades. DSteed Our Community 7 12-11-2018 01:12 PM
Stainless Upgrades. DSteed Our Community 0 12-03-2018 12:25 PM
$tainless Steel Upgrades Siegmann Exterior Storage Compartments & Access Doors 5 02-01-2016 08:02 PM
Stainless Steel panel upgrades - How to RMB General Repair Forum 2 11-05-2012 08:24 PM
