Old 02-10-2021, 02:04 PM   #1
2018 28' Tommy Bahama
Williamsburg , Virginia
Stainless steel GFI outlet covers
Airstream has a full line of outdoor stainless steel covers available with the exception of one for a 110v gfi outlet. I have seen one or two on trailers and would like to get one for my 27 foot 2019 Tommy Bahama, any ideas where to find one??
RichardBoyd is offline   Reply With Quote
Old 02-10-2021, 06:54 PM   #2
ITSNO60's Avatar
Tucson , AZ
A marine supply might have them but meanwhile what's wrong with this one?:https://airstreamsupplycompany.com/p...-outlet-cover/
edit: changed "would" to "might", marine supply has vertical but didn't see horizontal in SS
Brian
ITSNO60 is online now   Reply With Quote
Old 02-10-2021, 07:00 PM   #3
RivetED's Avatar
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas , USA
Originally Posted by ITSNO60 View Post
A marine supply would have them but meanwhile what's wrong with this one?:https://airstreamsupplycompany.com/p...-outlet-cover/
That's the one I put on our FC. Pretty easy install. We bought it at Jackson Center.
RivetED is offline   Reply With Quote
Old 02-10-2021, 07:34 PM   #4
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
Looks great. Just ordered one. I suspect that our current cover is letting in moisture and causing the GFI to trip.
SilverWind is offline   Reply With Quote
Old 02-11-2021, 06:55 AM   #5
Thank you all for the help just placed the order
Old 02-11-2021, 09:35 AM   #6
palm beach gardens , Florida
One thing to keep in mind when adding any stainless fittings is make sure they don't come in contact with the aluminum or you can get corrosion from dissimilar metals together. I know this from experience
m rafferty is offline   Reply With Quote
Old 02-11-2021, 06:07 PM   #7
RivetED's Avatar
Airstream - Other
Airstream - Other
Mine came with a foam gasket to keep the SS off the aluminum and provide a seal. The foam gasket has adhesive on one side and A/S told me the adhesive sticks the gasket to the SS not on the aluminum. Kinda counter-intuitive as there is adhesive on the overlapping part of the gasket that faces out.
There is also a 2nd gasket that goes inside the cover to 'seal' the outlet. It took a long time for that gasket to form and make a decent seal over the outlet.
Old 02-11-2021, 06:12 PM   #8
ShawnSk's Avatar
2021 20' Bambi
FREDERICKSBURG , VA
PASS & SEYMOUR WPH26 is basically the same thing for about $40
ShawnSk is offline   Reply With Quote
Old 02-11-2021, 06:25 PM   #9
sparkymark's Avatar
2012 25' FB Eddie Bauer
laguna beach , California
Go to an electrical wholesale or home cheapo
sparkymark is offline   Reply With Quote
Stainless steel hub dust covers adonh Wheels, Hubs & Bearings 6 07-13-2020 06:25 PM
Stainless steel exterior receptacle covers with exposed screws? RxGuy Electronics & Connectivity 1 09-08-2017 11:10 AM
Stainless steel exterior receptacle covers Gneiss Guy Electronics & Connectivity 18 10-02-2016 05:04 PM
Stainless steel wheel covers. gloran Airstream Classifieds 0 04-08-2015 03:39 PM
Stainless steel upgrade for TV/Sat connection and exterior electrical outlet on curb GLovedahl Exterior Storage Compartments & Access Doors 2 03-13-2015 07:38 AM
