Originally Posted by HoldenGatt
Thanks A W Warn. The seller has notified us that he has the banana wraps. There is no belly pan. Not sure the tank covers are there. The wheel well liners are there but they have cracks. So they will likely have to be replaced. Is is possible to replace those without lifting the shell off again? Is any of this possible to fix without lifting the shell off again?
Could you explain what the vinyl insert and the aluminum extrusion are? And what are the tank covers?
In the photo in your first post look at the blue strip at the bottom of the door.
The blue is a vinyl insert. It is held in place by an extruded aluminum shape. Together these two pieces of trim are call a rub rail, and some people call it a beltline.
The rub rail should extend around the perimeter of the trailer. The aluminum extrusion is riveted or screwed over the metal joint where the wall metal and belly metal meet.(the belly metal should be lapped beneath the skin to shed water, but most of the time it is not and water ends up leaking into the belly pan causing corrosion) The vinyl insert slips into grooves in the extrusion and covers all of the fasteners.
The tank cover is a surround for the water and sewer tanks. It is a heavy galvanized steel sheet metal fabrication that protects the tanks from road debris impacts. There is a layer of foam insulation inside the tank cover that keeps the liquid in the tank from freezing. From the furnace there should a small duct going through the floor into the interior of the tank cover.
Also missing are the belt line terminations. Each place there is an interruption in the rub rail there is a special cast aluminum trim.
http://odmrv.com/catalog/index.php?m...yword=beltline
If you look at the weblink above, you will see that the Airstream dealers dont have the parts, you will have to search.
I feel homeless
Alan
Former Airstream Owner
(1973 31' Excella, 1978 31' Excella, 1987 32' Excella, 1999 30' Excella, 2000 25' Safari)
