Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 10-21-2021, 12:42 PM   #1
1973 31' Sovereign
Poland , Maine
KT Lock assembly reassembly snafu
Oh, noÖ.Iím just taking my KT lock assembly apart on my Ď73 Sovereign.
I pulled two small pins to release a spring and was able to pull out the angled bolt that fits into the door frame, which hold the door right into the body of the trailer.
Am cleaning all the parts for reassembly.
Thereís a small lock lever, with seemingly like a brass head which moves up and down as the key engages a small mechanism. It also locks the door from inside I believe..
When all of this was apart (and still is), I tipped it upside down to get a different view, and a very very small round ball bearing dropped to the ground! Aaah, where did that come from? Somehow I found it on the floor luckily! But I donít dare to put it together again until I know where the ball bearing goes.
Anyone know?? Any guesses? Any KT lock experts out there??
Iíll try and post pics.
Thank you!!
Shapmaui is offline   Reply With Quote
Old 10-21-2021, 12:43 PM   #2
1973 31' Sovereign
Poland , Maine
It seems now that the ball bearing is out, that the locking mechanism is sticking, where before it was a smooth turn of the key. Now itís not a smooth turnÖ
Old 10-21-2021, 12:49 PM   #3
1973 31' Sovereign
Poland , Maine
More photos
# 1 and 3 photo show the “brass” head mechanism.
#4 photo shows the back of the key entry. It’s a round piece with an “o locking ring nut” on it. Which is just to the right of a vertical part that receives the brass head pin.
ID:	406723   Click image for larger version
ID:	406725   Click image for larger version
Old 10-21-2021, 01:51 PM   #4
1973 31' Sovereign
Poland , Maine
I put the KT back together without the ball bearing - and reinstalled in the door to test. The cleanup of the lock worked amazingly well on the bolt action. Buuuut, I figured out that the ball bearing allows the brass head “pin” to stay in the unlocked position, when the door key is used. Without the ball bearing, the pin drops and stays into a slot of the bolt mechanism, keeping the bolt from receeding into the door. Basically making it locked all the time..Hmmmm, I think I found a small hole it goes into, but it just drops out very easily. Not sure how to replace it correctly..
Old 10-22-2021, 05:04 PM   #5
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Do you have a deadbolt as well? I spent a lot of time cleaning up the same lock on our '74 and putting back together before realizing that since I didn't have a key I was better off if the door could not be accidentally locked, so I took out the parts that allow it to be locked and covered up the hole where that little lever sticks out on the inside. One less thing to think about.
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
1965 Avion C-10 Truck Camper (65avion.home.blog)
DavidsonOverlander is offline   Reply With Quote
Old 10-22-2021, 06:28 PM   #6
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
If you will take the small allen head screw out on the end where the shaft slides in a small spring will fall out. If your locking shaft is slide back into the lock where your key moves it to lock and unlock you can drop the bearing back in the hole then the spring and replace the allen head screw. Tighten the screw until the shaft has tension this is the locking rod. I have rebuilt numerous KT locks this happens a lot. Put a rag under your lock while taking apart and putting parts back saves you money. Good luck.
cole3444 is offline   Reply With Quote
Old 10-23-2021, 07:46 AM   #7
1973 31' Sovereign
Poland , Maine
I think I will be getting a deadbolt for this. And disabling the locking mechanism as you suggested.
Need to focus on a good deadbolt. One that requires the min of metal work. I am not experienced in cutting metalÖ.
Old 10-23-2021, 07:55 AM   #8
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
Images: 48
cole3444 is right.
the ball goes in from edge of door side under the screw and spring. and holds the lock retainer rod in position up or down.
your roll pin looks to be in fine shape. your door lock should work just fine when you get it back together. this area circled in red is the trouble spot I found
"Daddy when's the trailer going to be finished?"
Can of beans is offline   Reply With Quote
Old 10-23-2021, 08:12 AM   #9
1964 26' Overlander
Milton , ON
Check out the one at Vintage Trailer Supply that minimizes the size of the hole in the door frame. It's not cheap, but it reduces the chance that your doorframe will crack, and that's a lot of work to fix. The deadbolt can be mounted in the wall to the front of the door.
1974 Sovereign
TAC ON-5
Old 10-24-2021, 04:08 AM   #10
1973 31' Sovereign
Poland , Maine
Originally Posted by Can of beans View Post
cole3444 is right.
I spoke the other day to an older expert locksmith, who works on vintage locks, he was from Phoenix area, and he said I could learn like he did. Take the old lock to the kitchen table, take it apart, put it back together, and do that again and again..
All the parts after cleaning seem solid including that roll pin. I see the opening where the set screw is. I understand I need to take that out, and place the spring and bearing and replace the set screw with tensioning. But, on the complete other end of that ďtunnelĒ where the spring, bearing and set screw go, is an open hole/opening, so the ball just drops out of that.. This opening is very hard to see at first, and itís on an inner wall of a 4 wall small compartment. It seems like another screw went in that opening. . Or something closed that opening. Iíve put my lock back on in the meantime and have the lock arm lifted by a wire for now. Iíll take it out again and try to take a photo of where this opening is, in case you canít follow what Iím describing. Again, if you were to open the outer set screw, take out the spring and bearing, and look through the now empty ďslotĒ or tunnel, you could see all the way through to daylight on the lock I have..I need to close up that daylight on that far side, but itís in such a tiny space, Iím not sure how to tackle it..
Old 10-24-2021, 04:17 AM   #11
1973 31' Sovereign
Poland , Maine
TY. If you have a second to check out my response in #10 above, where I describe the issue in more detail, I hope it might clarify what Iím facing, and thanks for your comments, this is all very helpful.
Old 10-24-2021, 06:55 AM   #12
1971 31' Sovereign
1972 31' Sovereign
The fourth picture in post three is what holds the ball and spring in place. The shaft moves when the lock cylinder is turned and the ball puts tension on the shaft.
Bathroom pocket door reassembly Sprouty All Argosy Trailers 0 03-12-2014 01:38 PM
Our first winter "snafu" ...... truxpin Winter Living 9 12-08-2013 08:15 AM
Winterizing snafu - low point drain valve on FW tank stripped and won't opem bonginator Fresh Water Systems 12 09-29-2013 03:22 PM
Forgetting what on last sheet (bath out) reassembly? Wabbiteer Repairing/Replacing Floor &/or Frame 12 05-31-2007 01:51 PM
AS Parts SNAFU! Turtle Windows & Screens 1 10-02-2005 07:43 AM
