Originally Posted by bigredandoldblue
1998 31' Classic TB did not come with the exterior light that is usually located under the exhaust vent for the stove. I have one to install but I'm not sure how wide the rib blocking is. I have to drill a hole to feed the light fixture wires through to connect the wiring from the new switch.
To visualize the ribs from the outside of your trailer you will observe vertical rivet lines. The rivet line will start down at the floor and extend upward to the center of the roof. That rivet line will indicate the possition of the ribs. OK so far? In-between the vertical rib lines should be a 2 or 3 rivets connecting the ribs horizontally. I believe that will be the "rib blocking" you are referring to. In my 64 Safari there are blockings down a foot or so off the floor and up close to the roof where it starts the radius, then another on the roof near the center. I hope this helps.
-Dennis
