Top Down
I usually start in later afternoon/early evening after the heat of the day to give time to dry.
start at the top hosing it all down, getting dust/dirt/bugs off with water only, then car soap with a soft bristle brush on extended handle top only, then hose it all again, under carriage included (we go to the coast a lot), sea air film, all with brush, then front around side where windows stop, then back, same window routine with hand mitt, then sides, then wheels/tires. hose it all off one last time with my special "no spot" water sheeting hose end. Open the awnings (that is where all my water drips from) towel dry windows, then top down front to back.
I store indoors, so no gunk other than from camping under trees. I rinse it off after any time at the coast and prior to storage each time. I have a microwax applied, really helps the gunk not stick.
takes two hours if I do it by myself, little less if the wife cleans the windows.
takes longer to wash the truck.
2021 International 27 FBT - 2019 F150 Harley Davidson
2017 FC 23 FB - 2002 Range Rover
