Yep, testing with a tiny dab of toothpate on your finger will tell you. Make sure you clean off the area you are testing with water first.
The fact is, if your trailer is a 1975, it probably has clearcoat in different phases of failure on it unless someone before you stripped it or it was always stored indoors out of the elements. So some areas - usually the top - won't have good clearcoat and other areas more protected from the sun & weather like the bottom sides will have more clearcoat left. The "peeling sunburn" look you see in vintage Airstreams is due to the clearcoat failing over time and the exposed aluminum oxidizing more where the clearcoat has failed first. Older failures = more oxidation, which makes it look grayer.
Are you planning on polishing your trailer? If so, you will want to make sure
all the clearcoat is removed before starting to polish. We've polished two trailers - one 19' and another 22' - our '64 19-footer had failing clearcoat which needed to be stripped first, our '56 22-footer did not. With clearcoat, even with different stages of failure you have the extra step of stripping, but the areas that are still protected are easier to polish. Whereas without ever having clearcoat, there is a lot more polishing to remove the oxidation...either way, it's a lot of work!
A 26 ft Overlander is a lot to polish, but they sure look look great when done! Good luck!
Shari
