Old 12-15-2021, 08:41 PM   #1
1965 24' Tradewind
San Diego , California
Hehr Window Drip Caps - 1965
Happy holidays. I finally got a quality sheet metal brake for Christmas and will be fabricating new drip rails (full Monty restoration and Iím missing the drip rail on the rear window and half of the others have wallowed out rivet holes from removal, too big for modified brazier). Does anyone know what sheet metal type was used? Itís 0.032Ē. Should be suitable for brake bending and has to be polishable to mirror finish. 2024T3 Alclad used for skins is a no go. Not very bendable, way too stiff. I donít know that belly pan 5052 H32 takes well to mirror polishing. Considering 3003H14 but no experience with this type. Thanks!
65TW is offline   Reply With Quote
Old 12-15-2021, 09:15 PM   #2
1966 22' Safari
Fredericksburg , Texas
Iíve used 3003H14 to make a few storage compartment doors on early 60s. Worked fine and polished well. The go to guy on exactly what type of aluminum to use would be Kip (Aerowood on the Forums). Good luck
Bubba L is offline   Reply With Quote
Old 12-16-2021, 08:34 AM   #3
1965 24' Tradewind
Thanks, I appreciate you sharing your experience. Iíll give the 3003 a try.
Drip, drip, drip. Or not to drip? Vitaver Plumbing - Systems & Fixtures 9 12-19-2016 07:25 PM
drip- drip-drip-drip-drip.... AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-09-2009 07:32 AM
Arrggggg! Drip, Drip, DripóWarning, plumbing questions Jim & Susan Sinks, Showers & Toilets 16 06-10-2009 08:04 PM
Drip, Drip, Drip kamadeca Fresh Water Systems 4 05-20-2008 08:22 PM
AC drip,drip,drip,drip,drip Canuks Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-02-2006 02:05 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
