Hello, I recently bought a 1962 Safari and have removed the shell for a frame replacement. It did not come with any subfloor that I can use as a pattern. Does anyone have any suggestions on how to make the curve end plywood pieces. Is there a pattern available?
I took heavy duty paper floor covering, traced the corners, then taped the pieces together. Then I rolled it up and used it for patterns for the subfloor and the Marmoleum. Finally I put it back down for floor protection after the Marmoleum was installed. It was useful to pop lines for the cabinet locations. Good luck
