RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 09-19-2020, 07:52 AM   #1
1962 22' Safari
Kingman , Arizona
Door gaskets 1962 safari.
I am trying to locate a source for replacement seals for a 1962 safari with the door in a door and are riveted on. I have spent two days looking. PLEASE
HELP
Safari 60 is offline   Reply With Quote
Old 09-19-2020, 09:11 AM   #2
batman's Avatar
1964 22' Safari
modesto , California
I have a 64 Safari with the "Door Within a Door". I have found gasket/weather stripping from 2 places that work.
1- (VTS) Vintage Trailer Supply - https://vintagetrailersupply.com/
2- Vintage Trailer Gaskets. https://www.vintagetrailergaskets.com/
They both have similar products, but different manufacturers. They will both send you samples to try. VTS charges for there samples, Vintage trailer gaskets did not charge me for there samples. I have used both sources for my windows and door.
P.S. No one makes the exact gaskets that came stock on these years. You will have to take measurements and use the size and style that will work in your application.
For example, I used the MED. D-seal 1/2" wide x 3/8" tall from VTS for the inside door within a door gasket.
Hope that helps,
-Dennis
ID:	378972   Click image for larger version
batman is offline   Reply With Quote
Old 09-19-2020, 02:44 PM   #3
1962 22' Safari
Kingman , Arizona
Thanks Dennis
I have done business with VTS and will give them a call.
Correct door gaskets for 1964 Safari jcarnevale Windows, Doors, Locks & Vents 1 05-02-2018 05:45 PM
Part Numbers needed for Window and door gaskets Dog Doc Windows & Screens 2 04-24-2011 08:30 PM
Window & door gaskets/seals for a 1969 Caravel scottwtalley 1969-1971 Caravel 4 08-10-2010 01:04 PM
Door Gaskets rollingbubel Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 02-24-2009 02:54 PM
door gaskets in 1974 Chas Doors & Locks 14 04-19-2003 10:11 PM
