Old 08-06-2017, 01:30 PM   #1
1974 21' Globetrotter
Priest Lake , Idaho
Caulk for trim
I was told to caulk the top of the trim around the bottom of my 1974 Globetrotter. Any suggestions on what kind of caulk to use?
carmangel is offline   Reply With Quote
Old 08-06-2017, 02:09 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I like Parbond in aluminum color. I put on a fine bead, then use a mineral spirits soaked cloth to push it into the crack and wipe off the excess.
CRH is offline   Reply With Quote
Old 08-06-2017, 02:13 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Old 08-06-2017, 03:36 PM   #4
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Silicone (RTV) caulk is normally the "best stuff" for most applications. The standard varieties give off acetic acid when they cure. That's not a good thing for a number of metals, aluminum being one of them. There are "Aluminum safe" flavors, good luck finding them at the Dollar General
Old 08-06-2017, 05:06 PM   #5
1977 Argosy 24
Milltown , Wisconsin
I have found Parbond gets hard as a rock after a year or two, cracks and can fall off. I would use something else, unless you like re doing it every year.
ventport is offline   Reply With Quote
Old 08-06-2017, 05:14 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
I last appiled Parbond 3 years ago this summer. Mine is still in good shape.
Old 10-03-2017, 04:26 PM   #7
1995 30' Excella
Harper Woods , Michigan
I've never found silicone caulk or glue to be satisfactory in the long term except on glass and glass-like surfaces such as ceramic tile. It will also adhere well to stainless steel.
It should be noted that many if not all silicone RTV adhesives/caulks are almost transparent to water vapor, although they repel water droplets. This property leads to infiltration and eventual separation of the bond between the silicone and most substrates.
Bob Blarney is offline   Reply With Quote
Caulk caulk and more caulk amazingwoody Leaks - Weatherstrips, Gaskets, Caulks & Sealants 28 03-23-2015 10:16 AM
To Caulk or not to Caulk? marchesi Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-24-2009 10:43 AM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
