Old 08-28-2020, 03:23 PM   #1
beckettnole's Avatar
Best drill bit for removing rivets?
Has anyone found a great drill bit for taking out rivets? Mine breaks often
Any special techniques you’d recommend?
Thanks for your advice as always
Ryan
1965 International
Palm Beach, FL
beckettnole is offline   Reply With Quote
Old 08-28-2020, 03:32 PM   #2
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
I use titanium bits with thick bar oil to keep temps down. If you are planning on doing a lot and have an air compressor, I highly recommend one of these... https://www.harborfreight.com/3-16-i...ter-93458.html
s1000pre is offline   Reply With Quote
Old 08-28-2020, 03:50 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I just use a quality HSS bit. Brad point for the 3/16. Regular point for the 1/8 and 5/32. Broken bits sounds to me like the nitrite coated imported bits. Be a little picky and a little spendy when buying bits that are going to get used a lot.
Old 08-28-2020, 04:24 PM   #4
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
I've had good luck with miniature step bits, not the short stubby ones but the long thin ones. The short fat ones sometimes hang up and just spin the rivet.
Brian
ITSNO60 is online now   Reply With Quote
Old 08-28-2020, 06:28 PM   #5
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
Quick answer; order some from an aviation materials supplier in the correct size. #30 to remove 1/8" rivets. Somewhere like airpartsinc.com, brown tools or similar. One bit should do a whole trailer unless your pushing tool hard or using a cordless drill or something slow and heavy. :-)
truckasaurus is offline   Reply With Quote
Old 08-29-2020, 09:12 AM   #6
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
Also, having a non-pointy scratch awl can be useful for those stubborn rivets. I happened to have a broken awl handy, but finding a cheapo and grinding the tip to about 1/8" will also do.
Some small linesman's pliers are good to remove the "trophies" that collect on the drill bit.
SuzyHomemakr is offline   Reply With Quote
Old 08-29-2020, 09:27 AM   #7
2023 28' Pottery Barn
2019 23' International
Tomball , Texas
https://www.aircraftspruce.com/catal...obaltdrill.php
B17drvr is offline   Reply With Quote
Old 08-29-2020, 09:32 AM   #8
gr.austin's Avatar
2009 27' FB Classic
Sioux Falls , South Dakota
They make shorter drill bits (jobber) shorter will be less likely to break. Also on small diameter bits make sure the speed is very high 3000 RPM+ slower speeds cause breakage. That is the reason for the air power drill it has a higher RPM.
gr.austin is offline   Reply With Quote
Old 08-29-2020, 09:40 AM   #9
batman's Avatar
1964 22' Safari
modesto , California
Jobber bits are shorter, cheaper and less likely to break. Fastenal carries them. Order a package of them.
-Dennis
batman is offline   Reply With Quote
Old 08-29-2020, 09:50 AM   #10
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
1/8" for 1/8" rivets
that way you can rivet the same hole
waninae39 is offline   Reply With Quote
Old 08-29-2020, 10:01 AM   #11
Images: 59
Use #30 with an air drill. Split point bits work best. Center the bit in the dimple and give it a quarter turn by hand before drilling and you won't need a center punch, if the bit is sharp.
Old 08-29-2020, 12:58 PM   #12
Tom T
Tom_T's Avatar
Orange , California
Ryan -
In addition to the bit types, aviation supply & other sources above - Vintage Trailer Supply also sells bits for rivet removal, as well as rivets & tools:
https://vintagetrailersupply.com/ext...and-fasteners/
Cheers!
Tom
Tom T
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-22 Cayenne S, EH, etc
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
Tom_T is offline   Reply With Quote
Old 08-30-2020, 08:39 AM   #13
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
Originally Posted by Tom_T View Post
Ryan -
Cheers!
Tom
Agree with Tom ...check out Vintage for everything to remove and replace rivets
rucos is offline   Reply With Quote
Old 09-01-2020, 06:04 AM   #14
Eric 26 Argo's Avatar
Airstream - Other
Knoxville , TN
My experience has been that bit break for two reasons. 1. cheap bits. 2. side pressure. I will break small bits much quicker with a 18 volt cordless drill due to the side pressure as a result of the heavy battery. I found using a 12 volt with the 1.5 a/h battery is both easier on the drill bits and my arm. When I was taking my Argosy 26 apart I broke a couple of bits with my 18 volt drill then went through a pack of harbor freight bits in about an hour. I went and bought some name brand bits then finished the job with two bits and my 12 volt drill. I still have the two bits and they work fine a year later.
Eric 26 Argo is offline   Reply With Quote
Old 09-01-2020, 06:22 AM   #15
Perpetually Perplexed
Krek's Avatar
Mobile Rail Bunkhouse
Farmington , MO
VTS was out of stock on this tool so I grabbed it from Amazon, much quicker and easier than center punching each bucked rivet first.
https://www.amazon.com/Aircraft-Tool.../dp/B005VR2L3Q
Krek is offline   Reply With Quote
Old 09-02-2020, 07:31 AM   #16
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
I learned a long time ago with small bits to hold the drill at the motor directly opposite the bit, not by the handle. This way you get steady, even downward pressure more like a drill press instead of the side pressure that snaps bits.
Brian
Old 09-03-2020, 06:45 AM   #17
1972 29' Ambassador
Here's another idea... you can get a cute little friction chuck for a Dremmel tool. That's what I use around the shop when using tiny drill bits. I wouldn't want to do an entire trailer with it, but it could be useful for those hard-to-reach places.
Right Size Drill Bit For Olympic Rivets VeggieBullet Ribs, Skins & Rivets 76 03-22-2022 08:48 AM
Removing interior skin rivets -don't drill -strike off the head & punch the rest Bob Blarney Interior Restoration Forum 7 07-08-2018 03:11 PM
Solar to drill or not to drill-HELP Orson Electrical - Systems, Generators, Batteries & Solar 2 08-24-2012 08:03 AM
Drill Baby, Drill! Mount external antenna TropicGuy Computers, Internet & Satellite 5 04-17-2010 03:02 PM
Drill Bit Conversion Chart pap Ribs, Skins & Rivets 2 03-17-2003 09:33 PM
