12-23-2019, 03:57 PM
2016 27' International
San Anselmo
A Major step up
As full timers, we have little observed the process of passing into and out of our "Silver Submarine" until the bounciness of the steps became more noticeable. Upon closer examination of the step assembly, I saw two cracks in the support assembly of our four year old International Serenity, and set about researching alternatives over and above a simple Airstream replacement. I discovered the company, Torklift, found their model "Glowstep Revolution, liked what I saw that I will describe in just a moment, and then found in an Air Forum series of stair postings, someone who had just had this company's brand stairs installed at Jackson Center.
I called the T.L. company representatives, explained our need, and sent them complete measured specs of our stair opening and attachment bolt positions. They proceeded to manufacture brackets that would allow me to remove our existing floating and bouncy stairs and install their much more stable system.
The strength of the Torklift stair system lies in its ability to adjust the stair positions relative to the ground in three positions, and then allow feet to be adjusted in five positions independently to stabilize to an uneven ground. Now, when we enter and leave, the "trampoline effect" is gone! The set up and break down is child simple, and a bonus is the glow in the dark squares framing both sides of each stair. Their system allows the addition of more stairs if needed, but I suppose most of us Airstreamers share similar height dimensions.
I was able to self install in about an hour, with my wife helping support the stairs while I ratcheted them snugly into the brackets. In my humble opinion, we now have a stair entry system the envy of every Airstream, or for that matter any RV owner.
Check out these pics. (If one of the pics is flipped, I apologize. I've tried every possible flip to no effect.)
12-23-2019, 04:14 PM
Rivets?
1992 29' Excella
2010 22' Interstate
Van By The River
, Georgia
Sounds like an interesting alternative and a very good long-term solution for your Airstream.
If I understand the design correctly... depending on how low (or high) the surrounding terrain is relative to the trailer the "rise" of the step system adjusts to the overall rise from ground to trailer. Depending on the terrain, the first step (from ground to step) might be higher or lower than the remaining "risers" but that's true with the existing steps too.
Good to know the step manufacturer is so accommodating.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
12-23-2019, 06:54 PM
2018 27' Tommy Bahama
Marana
Very nice! Which version fit your AS? Can you share the cost as well as that does not seem to be published on their site. Thanks!
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
12-23-2019, 07:06 PM
2019 30' International
Pennsylvania
, Pennsylvania
Very nice, could you post some pics of the attachment points, and maybe the steps in their stored for travel position?
thanks!
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
12-24-2019, 03:33 AM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Interested in these. My old steps (2012 - not the Airstream Flip and fold) have had a couple of close encounters with rocks and snow load... could use a replacement. Definitely would like to see installation points. Thanks.
Paula
12-24-2019, 06:07 AM
2017 25' International
Port Dover
, ON Canada
Do these need to have the feet on the ground - even for a quick entry/exit at a rest stop while travelling, for example?
Ray B.
12-24-2019, 07:10 AM
2014 25' Flying Cloud
New Ashford
, Massachusetts
Hi,
Looks good. I'll ask what everyone is thinking, How much $$$$?
Joe D
12-24-2019, 10:22 AM
2019 25' International
Washington
, Washington, D.C.
Following . . . .
12-24-2019, 11:13 AM
1989 34' Limited
1979 29' Ambassador
Ashland
, Kentucky
Very nice!
12-24-2019, 11:57 AM
1976 31' Excella 500
Chappell Hill
I need these.
12-25-2019, 06:29 AM
1958 26' Overlander
Battle Ground
I installed a Tork Lift when we rebuilt our 58. Been in use for over 2 years. Suggest a little lubricant on the pivot points once in a while. No issues with not adjusting feet when opened for a short stop.
My frame rails are only 4" tall so the unit extends below the belly pan. I lifted our trailer by using a straight axle and larger tires. The belly pan has 18" ground clearance and the stairs have 10".
12-25-2019, 02:47 PM
San Anselmo
Yes, you are correct. Because the stairs connect to a 3 position cam, they pretty much stay equidistant, and the bottom feet adjust in five positions to make this easier.
12-25-2019, 02:52 PM
San Anselmo
Here is a direct link to Torklift
https://www.torklift.com/rv/glowstep-revolution
with more details, and links to Youtube video tours. I spent right around $500.
12-25-2019, 02:54 PM
San Anselmo
The process of deploying the stairs is quite quick and the feet naturally come into a down position. I never tried to use them without landing the feet which might require a second or two more :^)
12-25-2019, 03:17 PM
San Anselmo
There are four existing bolts supporting our Airstream stairs, two on each side fore and aft. The "L" brackets that Torklift supplies for us match up perfectly with these Cap Screws (bolt holes), and the stairs fit into them in turn.
For those interested in ordering these stairs, a call to their sales team, after doing some measuring as mentioned on their website, will clarify any questions.
Note the placement of the stairs closed. There is a lever on each side of the stairs to enable deployment, if you are left or right handed. Upon releasing the safety pin on the left side, when you lift the release lever you choose one of three cam lock positions for the stairs to land depending on the terrain. The Youtube video shows this in action. Again, I apologize for the improper rotation of this pic. I've tried saving it in four 90 degree positions, and the Air Forums site won't take it.
12-25-2019, 08:23 PM
2007 22' International CCD
Corona
Thanks for the information. I need to replace bent steps as well.
12-26-2019, 09:08 AM
Tampa
Help? (I just resized it from 1600 to 1550 and voila'. That seems to solve forum rotation issues.)
12-26-2019, 09:14 AM
Tampa
I've been using this since my MH days.
Super sturdy, I leave the legs out and store it inside the door while underway.
I use the stock steps but don't flip the second step down.
12-26-2019, 10:36 AM
30' 1999 Excella
Kingwood
Exactly what we do...
I'm 6'2" and weigh 230lbs. I don't like the pressure my weight puts on the steps if I use on that second step.
Hey, its the only way to be sure!
