Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2007 Safari SE
Old 06-03-2007, 04:05 PM   #1
2007 25' Safari FB SE
Kennesaw , Georgia
Question Water leak mystery...
Well, we have a slight water leak that appears to be coming from the water pump that is behind the access door tucked under the storage closet (between shower and fridge). Seems to happen whether water pump is active (boondocking) or not. Shower is not a factor; it has not been used for several days. Will take it into dealer, but has anyone else seen this?
Thanx, Lance
TennisMan is offline   Reply With Quote
Old 06-03-2007, 06:40 PM   #2
Lake Forest , Illinois
No. We have not experienced this type of leak but I am certain the dealer will tighten a loose fitting. Good Luck
woodedareas is offline   Reply With Quote
Leak somewhere in top section- B190 Van Luckydog Sprinter and B-van Forum 5 04-09-2010 05:09 PM
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 08:28 AM
Water Drip uwe Fresh Water Systems 6 07-11-2002 08:39 AM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
