We have the queen bed in a 2005 25' FB. We had the same problem. We now use a fitted full sheet and a queen flat sheet. The fitted sheet is tight, but it works and we use a 2" memory foam top pad. Without a pad, the full should fit fine.
__________________ SuEllyn & Brian McCabe WBCCI #3628 -- AIR #14872 -- TAC #FL-7 2015 FC 25' FB (Lucy) with ProPride 2020 Silverado 2500 (Vivian) 2023 Rivian R1T (Opal)
We have those elastic corner straps that snap on across the corners. This is because my wife wanted Egyptian Cotton sheets...oh so soft and very nice. I would think you could also sew in a pleat or seam or something to take up the slack in the corners of the fitted sheets if you wanted a custom fit.
2006 30' Safari - "Changes in Latitudes"
2008 F-250 Lariat Power Stroke Diesel Crew Cab SWB
Family of Disney Fanatics
WBCCI# 4821 https://streaminacrossamerica.com/
