03-22-2015, 01:46 PM
#501
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
"Airstream not reacting to owners' cases and correcting assembler performance is inexcusable" - Maybe a more detail re-read is in order?
As for owners doing the 'required' maintenance to prevent leaks, I was not referring to the manual but ownership experience. Not all leaks stem from the "no sealant" problem but rather from sealant/seam/gaskets failure due to age, UV, etc., and that water finds it way to the floor. I have discovered and repaired leaks and damage in my unit. The Airforums provided great insight into the how, when, where, what for those adventures. Yes, it can happen repeatedly despite regular attention and a meticulous nature.
Going beyond the dictionary for a definition and expected remedy:
The warranty period is the 'defects liability period' but it may not end then under the 'statutory liability period' remedy option. Statutory is generally six years but you'd have to research your jurisdiction and RV applicability specifically.
In 1986, the Latent Damage Act introduced an extension to the ordinary six-year statutory limitation period. This extension is available for negligence claims for latent defects – a defect in a property, caused by a fault in design, materials or workmanship, that existed at the time construction (the day of assembly re: Airstream) was completed but was not apparent at the time of completion. Whether the Act is applicable to your Travel Trailer is a conversation you can have with your lawyer. FYI, The Act does not apply to personal injury claims (from say stepping through a rotten floor).
In my case, the trailer was badged with an October 2002 build date (start of the statutory period) and it took over ten years before the first "leak" appeared so I can only look to myself for remedy. I still discover a new source every six months or so and keep the moisture meter handy.
Any implied feelings of condescension or insult taken by others are NOT intentional and I don't expect an apology from those still in the emotional stage of dealing with the issue(s). If you are unhappy the first time, just wait until it starts all over again after you've fixed it permanently.
03-28-2015, 03:08 AM
#502
Seattle
, USA
I was actually surprised to see this:
On my trailer, I have removed the rear taillights to repair the corrosion. However, my trailer has plastic "cups" mounted between the inner and outer skin; there was no exposed insulation nor could I see or touch the internal aluminum skin.
The plastic "cups" are a bit bigger than the taillight assembly themselves, and sealed to the external aluminum skin from behind; they aren't riveted. On my trailer, these internal plastic cups are sealed all the way around; there is no way for water to enter the trailer here unless the sealant fails. As a matter of fact, when I reinstalled my taillights I didn't seal around them since those plastic cups are sealed to the external skin from behind; I didn't see a reason for more sealant. I've had no leaks.
Apparently there was a time when Airstream stopped using these plastic backing cups and just started bolting the external taillight assemblies right to the skin leaving that giant hole to the inside of the trailer...but when is anyone's guess.
07-18-2015, 01:09 PM
#503
2008 27' Safari FB SE
Port Ludlow
Rotten floor due to water leak!
I've been following this thread since 2009 because I have a 2008 Safari 27FB. I've checked frequently beneath my dinette for softness and found none. But this season I noticed the vinyl flooring loose at the edge, and I could feel moist wood there. I removed the corner seat and pulled back the vinyl to discover some rot, like Tennis Man's, but not under the dinette. I carved out soft wood from a 8" circle near the entry. I also found some superficial rotting near the edge of the floor, under the rear windows. I hesitate to blame Airstream for this; I know I had seepage one (Olympic Peninsula!) winter through weep holes in the wraparounds. I resealed the glass, but months later found the gutters beneath them filling up again and spilling out. I finally discovered a seal in the opening window leaked and was filling its frame, then spilling over to the gutters on each side. The rot near the entry must have been in a low spot where moisture collected. I never saw a leak around the door.
I aim to fix this myself when this season is over, and replace the floor covering. I've dropped some of the belly pan and it doesn't look awful under there. I will take the trim piece off above the tool box and check that for sealant. What is the best way to deal with these rotten spots? Wood hardener and epoxy fill? Remove whole sheets? Most of the wood is OK as it dries out; if I can avoid replacing them I will.
07-18-2015, 02:18 PM
#504
Dazed and Confused
Hillsburgh
, Ontario
Originally Posted by Don.H
It seems to me that the major issues with the Air Stream RV could be corrected with a few cents worth of wood preserative and a little calking . Why do they want to risk their reputation and future sales to save A few cents . The additional cost could be added to the cost of the AS or make it an option when purchasing the AS . I will never understand their reasoning . I hate to have mine outside out of the garage on a rainy day.
If Airstream were serious about solving this problem once and for all they would use a man made substrate like Coosa board. Waterproof, mildew-proof, fungus proof, 40-45% lighter than plywood and just as strong; easily machined and worth every penny in peace of mind. It doesn't stop water from leaking in through mouldings, windows or plumbing accidents, but it limits the amount of damage water can do.
As I have stated many times over......If I were to order a new trailer from Airstream, I would drop off the sheets of Coosa to the factory floor myself.
Cheers
Tony
08-17-2015, 04:53 PM
#505
1989 32' Excella
Sharon Springs
, New York
Looking at purchasing a 2005 AS Safari 28' w/slideout, have read blogs on leak issues and I am concerned. I replaced the floor in my Lance slide-on and it was interesting at best. I have to travel from upstate NY to VA to look at this unit so I don't know if it has a leakage problem yet, but if it is good to go, how much $ is a decent price? The owners are asking 29k, sounds OK, but is it? Any info/opinions would help... Regards...
08-17-2015, 05:17 PM
#506
Salem
, Oregon
Welcome to the Forum.
 Hi, for a 28' with slide out, If it just has normal wear, I would say that's a great price. I wouldn't sell my 2005 Safari 25-B for that price.
2005 Safari 25-B "Le Petit Chateau Argent" [ Small Silver Castle ] 2000 Navigator / 2014 F-150 Eco-Boost / Equal-i-zer / P-3 YAMAHA 2400 / AIR #12144
08-17-2015, 05:38 PM
#507
1989 32' Excella
Sharon Springs
, New York
Thanks Bob, I've owned a # of classes of RVs and have always wanted an AS, expect to pay the price, but my wife and I hope to transition to at least snowbirds(Texas-type) or full-timers and want to do it in an AS... Not afraid to repair/replace items(part of the fun, LOL), just wasn't sure of how much goes with these units and/or what years (used) are decent... Any/all advice appreciated... Regards
08-18-2015, 12:14 AM
#508
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
Easyrider - I couldn't tell from your comment if the floor in your slide was the issue so excuse my error if my response targets the wrong area to inspect. The way the slide is designed in the Airstream, I doubt water could effect the slide's floor area. If there is an issue, it would appear on the main floor at the bottom of the exterior gasket which is easy to check on the leading edge (closest to the tongue). Also inspect the rear edge which is more difficult to see. The cabinet between the refrigerator and the dinette hinders access to inspection area. Pull the drawers and poke the floor in the corner. Water has never entered my unit around the slideout but I have been especially careful to treat the gasket every six months since acquisition.
Moisture has entered my unit is the rear bedroom floor area from leaks at the junction of the rear exterior trunk and shell along the infamous joint so many others describe. I removed the 1 1/8" chrome-like banding and discovered there had never been any chalking/sealant applied at build! It was simple to seal and that cured the issue. Inspect the floor along the rear wall behind the bed from curbside window to street side window. If there is a problem, you will discover soft wood.
As for price, I am not aware of a slide matching your description of the unit for so low a price in the last few years. I assume there have been no modifications and all systems/appliances are original with visible carpet/fabric wear at $29k.
I've had two dealers tell me a number closer to $38-40 would move my unit within a week and it is a 2003 28' model. I, however, have upgraded most appliances (7 cubic ft reefer, ceramic toilet, 2 LED TVs, 3 multi-speed ceiling exhaust fans, etc.), installed vinyl flooring throughout, replaced the foam cushions, and re-upholstered all seating.
If it passes the flooring inspection and the systems work, I say go for it as the slides themselves are way over engineered compared to SOBs. Be aware I'm biased from years of very satisfied ownership
08-18-2015, 07:12 AM
#509
1989 32' Excella
Sharon Springs
, New York
See-more, thanks for the info, my Lance unit was actually a 2002 slide-on truck camper and we bought it with the soft floor. I repaired/replaced the floor and re-sealed the windows, vents, roof, A/C, etc., and never found out exactly where it was leaking from but she is "dry" for the moment and still in use. While we had slides in a M/H and they worked well, I see them as another mechanical issue especially in older units and I would prefer not to have them in my future AS. The unit I was to look at in VA disappeared off the site and the owner didn't respond to our email, I can only assume it was sold. We are back on the hunt and our AS will surface somewhere. What are your thoughts on A/S units from the 70s, 80s or 90s? I don't want to gut and restore a unit but am more than able to repair/replace items. Since my wife wants a bit more "room" LOL, looking for a 28'-30' unit and would prefer not to deal with dealers... one day at a time... Regards
08-18-2015, 06:58 PM
#510
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
At $29k, I'm sure the VA unit moved lightning quick.
Personally, each model and decade has something to offer. It all depends on what you believe you need (the list) and which aesthetic you desire. The Airstream site has a page which contains specifications and marketing pics for various models over the decades. Its a great place to start in your quest:
Document Archive - Airstream
Your Lance experience will be handy as you consider trailers. Like you, I'm leery of stuff that breaks and minimize that type headache wherever possible in all my acquisitions (cars, motorcycles, boats, trailers, et al). Electronics are the most painful on old trailers which usually get resolved with more modern replacements once watertight is achieved. Surprisingly, the slide has been the most reliable system in my trailer.
08-18-2015, 07:26 PM
#511
1989 32' Excella
Sharon Springs
, New York
Seemore, sent an email to a Minnesota owner who has a 1990 AS Excella 31 and it has allegedly been redone (pics look good) their asking 19.5k. It appears that structurally these units were strengthened from those in the 70s/early 80s. I asked about the unit's repair history, corrosion issues, etc. Haven't heard back yet but am considering finding an AS owner to inspect it for me although I'm willing to travel to check out the unit myself. Any info on early 90s units would help... Regards,
James
08-18-2015, 09:51 PM
#512
2006 19' International CCD
Olathe
, Kansas
08-18-2015, 10:29 PM
#513
1999 34' Excella
Hillsboro
James
Howdy.. have you noticed the folks willing to do 'inspections' on our forum?
Click the 'Portal' link on top left of the web based page. You will then be able to scroll down on the right side and will find a search for Inspectors by state and type. Contact someone in the area.. Perhaps they can be your 'eyes and ears' on site checking the AS you are considering.. best wishes..
Peace and Blessings..
Channing
WBCCI# 30676
08-19-2015, 10:17 AM
#514
1989 32' Excella
Sharon Springs
, New York
Channing, Thanks for the info, still learning this site plus, I worked with computers when they were coal-fired and have to go to my wife for help navigating (she's really good!). Got an email back from the owner of the 1990 AS and it sounds hopeful (bought new by her uncle and sold to her). Plan on making the trip next week to inspect, asked for additional pics of unit showing the undercarriage, bumper, A-frame, etc. to get a read on corrosion levels. I certainly expect "some" on a 25 year old unit and will also try to coordinate a local "inspector" to give me an eyes-on opinion before we travel from upstate NY. We'll keep you posted... Regards,
James and Rebecca
12-21-2015, 06:53 PM
#515
2009 27' FB International
_
, North Carolina
It’s been a while since I posted my issues with the rear floor in my 2009 27FB. Here’s an update and post with pictures and how I did my repairs in hopes that it will help others here that have the same issue. I will be doing this in parts so it isn’t one huge write up.
After talking with several other members on Airforums and other owners I met at RV Parks there was a trend in the similar treatment from Airstream on trying to get help and/or fixing issues. I was beyond frustrated and appalled at the common theme of Airstream’s treatment of their customers so I gave up on them. I’ve already vented earlier in the thread and won’t go into that part any more in this thread. The rest is about how I fixed the problem in hopes it will help others.
I wasn’t able to fix the floor over the winter due to various events in my life preventing me from doing so. I took it to a dealer in the springtime and was going to get it repaired by the dealer, but they had a heavy work load and kept pushing my start date back. I started a new job in the Summer and needed the Airstream to live in during the week for work so I decided to do the repair job myself while living in it. I tried to find a garage to work on it, but I couldn’t so I just got permission from the RV park owners where I am staying to work on it at my spot.
I talked with several members here about how to fix the floor and it was very helpful so thank you to those who helped with advice.
I wanted to see where the leaks were coming from before I started to cut up the floor and I didn’t want to spend a ton of money at a dealer to get it over pressure tested. I bought a nice air mover fan from amazon and cut a piece of plywood that would fit in the front storage compartment, and cut a hole in the plywood to fit the air mover fan so it would create a decent seal. I closed all the windows, sealed the fridge vent on the roof, and taped over the stove vent. It created a pretty good over pressure in the Airstream. If I opened the door a crack it created quite a wind whistle.
I then mixed a spray bottle with water and dish soap and sprayed all around the bumpers, windows, and pano windows. Here are the results.
The leak was from behind the trim on the rear bumper. The pano windows showed no leaks in the rear.
12-21-2015, 07:15 PM
#516
_
, North Carolina
12-21-2015, 07:40 PM
#517
_
, North Carolina
12-21-2015, 07:55 PM
#518
_
, North Carolina
I used a piece of foil insulation to make a rough template of the corner in the rear then cut it and made a template using the thin plywood. After measuring several times I used the thin plywood template and a T bar to mark out the cuts on the plywood sheet . I made marks just above where the floor would be on the wall to show were the bolts in the C channel are. After cutting the board I brought it into the Airstream and use the marks on the wall to mark where the cuts in the plywood would be.
I then cut the board in “V” shapes to account for the bolts in the C channel. When I finally got the board into the floor I had to cut bigger V shapes in the plywood than I had anticipated because I didn’t take into account the little bit of movement it would take when I got the board fit into the corner.
Hint- when you get frustrated with things not fitting just perfect quit for the day or take a break because I made several cuts bigger than I should have out of frustration. I later fiber glassed over the larger cuts and it worked, but it made me do extra work.
After cutting the v’s in the board to fit into the C channel the board was just a little too thick so I used a belt sander to sand down the edges so they would fit and the board would be level with the rest of the floor.
It took about 4 hours of sanding a little off at a time then taking the board into the trailer to see if it would fit. It was like a puzzle to get the sheet into the cut hole. I ended up having to cut a little on the edges to make it fit. I purposely worked slow and did a little at a time so it would fit as flush as possible.
I finally got the sanding and cutting right and it went in very nicely. You can see in the picture below where I cut a little too much of the V’s along the wall. I made marks on the board so I knew where I would have to fiberglass later.
12-21-2015, 07:59 PM
#519
2008 25' Safari FB SE
Victoria
, BC
Good Documentation.
Thanks for posting.
Consider getting rid of that Reflectix foil garbage under your new floor. It's not difficult to pull off the bottom skin and add real insulation under the floor; something that breathes, and doesn't hold any water up against the underside of the plywood. (See my post #299 on this thread for one option...)
-evan
12-21-2015, 08:11 PM
#520
_
, North Carolina
